new 1450 with snow blower
5 replies to this topic
#1 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted March 02, 2016 - 12:19 AM
i just bought a 1450 with snow blower - deck  my question is how high is the snow blower lift? mine only lifts a couple of inches it has a lift rod that is not painted maybe too long the blower has down pressure is that normal? this is the first snow blower i have ever owned
  • Bud said thank you
#2 EricFromPa ONLINE
EricFromPa
  • 4,003 Thanks
  • 3,265 posts
Posted March 02, 2016 - 06:07 AM
Sounds like it has a Lock-Out pin.The Lock-out pin is for Down Pressure while Plowing.You do Not want down pressure for Blowing or mowing.Remove the Tunnel cover and see if it has this Pin installed.
With Lock-Out Pin
Without Lock-Out pin
If it has this Pin Remove it and put it some place where you will remember where it is.
Can you Post a Pic of your Lift rod?
  • Bud, Traill95, BNK and 2 others have said thanks
#3 olds45512 ONLINE
olds45512
  • 1,358 Thanks
  • 680 posts
Posted March 02, 2016 - 09:20 AM
Every blower I've ever seen on a cub has only lifted a few inches so that's normal but you should check for the float lock pin as Eric suggested.
  • bill edler said thank you
#4 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted March 02, 2016 - 10:18 AM
I built a bracket that extended the lift arm because the plow would not lift high enough to get it on the trailer.  I curled the bottom under the arm for support, and if I leave the bolt a little loose I can get float for the plow only.  I think I have a pic somewhere...
  • Traill95 and bill edler have said thanks
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 06, 2016 - 08:43 PM
That's to be expected. Never had one that lifted more a couple inches. Have any pics. of the beast?
#6 IHCubGuy ONLINE
IHCubGuy
  • 1,592 Thanks
  • 1,633 posts
Posted March 06, 2016 - 09:25 PM
What model blower is it?  A QA42 or QA36 will only lift a few inches like the others have said.  I believe a QA42A or QA36A will lift a little bit higher because they have a parallel arm setup on them.  It's not much but I do believe it's more.
