Jacobsen Chief 800 part needed
clutch pulley jacobsen chief 800
32 replies to this topic
#1 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 01, 2016 - 12:28 PM
1968(close enough) Jacobsen Chief 800 needs a good used clutch/starter/pto pulley (large pulley nearest the 8HP kohler engine)
As many know the Ford 80 ( and maybe 100 ) are almost identical. So, any part help or leads would be appreciated.
An existing crack finally went all the way on the original pulley
  • KennyP and pick-to-stone have said thanks
#2 TimW OFFLINE
TimW
  • 419 Thanks
  • 272 posts
Posted March 01, 2016 - 09:52 PM
If you could post a pic of it, I may have it.
  • mpeck3 said thank you
#3 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 03, 2016 - 12:45 PM
  • pick-to-stone said thank you
#4 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted March 03, 2016 - 05:24 PM
hmmm. i think i might actually have one off a 7hp if it'll work im not sure
#5 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 03, 2016 - 05:32 PM
Wow. this sounds promising.  I can't see why they would have different dimensions, but not sure.
do you have basic dimensions available, or do you want mine ??  Thanks !
#6 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 03, 2016 - 05:35 PM
The shaft size could be different ...
#7 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 03, 2016 - 06:36 PM
Pulley dimensions on my pulley:
1)clutch face is 5 inches wide
2)large pulley is 8 inches wide
3)overall thickness of unit is 1 and 7/8ths inches
4)inside dimension of shaft opening is 1 and 3/8ths
#8 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 03, 2016 - 06:37 PM
also found a number on outside face of large pulley :  238021
  • VintageIronCollector and pick-to-stone have said thanks
#9 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted March 03, 2016 - 07:50 PM
i'll see if it tells me anything in the parts books
#10 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted March 03, 2016 - 07:57 PM
well its not telling me anything in the books. i'll have to try and see if i can remove it without breaking it.
#11 Dayton_King ONLINE
Dayton_King
  • 1,460 Thanks
  • 1,146 posts
Posted March 03, 2016 - 08:00 PM
Looks like thats the pulley off a manual or electric pto. I don't think the early jakes will work thomas
  • VintageIronCollector said thank you
#12 Dayton_King ONLINE
Dayton_King
  • 1,460 Thanks
  • 1,146 posts
Posted March 03, 2016 - 08:03 PM
All my pulleys are for no pto.
#13 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted March 04, 2016 - 08:48 AM
Interesting. As to removing, aside from a small
Lock screw, the pulley is not very tightly attached to the shaft.
Over time I think the lock screw applies enough pressure to cause a crack to form if the metal has any weakness. 40-50 years of tough work is not bad, however !
#14 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted March 13, 2016 - 12:44 AM
What is the pulley made of? If you cant find a replacement, and if it is a weldable metal, you could get your broken one welded, then drill the center and put a sleeve in it to fit the shaft without stressing the weld areas.
Obviously, replacement is better, but if you can't find one...
Or if you find a replacement with same pully dimensions but different size shaft - could bore or sleeve it to make it fit....
#15 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted March 13, 2016 - 02:31 PM
I have a complete ford 80 that has hand pto clutch on it. I will sell you the whole tractor.
Also tagged with one or more of these keywords: clutch pulley, jacobsen, chief 800
