P I T A SCISSOR JACKS
17 replies to this topic
#1 HANKG ONLINE
HANKG
  • 6,312 Thanks
  • 3,424 posts
Posted March 01, 2016 - 12:12 PM
I'm sure at one time or another we've all struggled with a scissor jack . I was removing 4 by 4 post's that were sunk in the ground about  3' and were not budging not even a wiggle,  after 20 yrs. they were set in there way's. I thought about jacking them out with a scissor jack because it can attain a higher scope. So instead of messing around with a jack handle and cranking it this was my solution, I nailed a 2 by 4 cross member to both post's put the jack in the middle and used this they were out in 10 sec. Put a drill key in your portable drill put it in the slot in the jack and pull the trigger.IMG_1359.JPG IMG_1360.JPG
  • Gtractor, MH81, hamman and 9 others have said thanks
#2 Jazz OFFLINE
Jazz
  • 2,393 Thanks
  • 1,441 posts
Posted March 01, 2016 - 12:19 PM
So,,,you got the posts out yet?  I had to remove 8 posts buried to 3'. I used my cherry picker, 3rd post blew the seal out of cylinder and learned where I can buy seals locally for all my hydraulic jack.
Edited by Jazz, March 01, 2016 - 12:21 PM.
  • KennyP, boyscout862, HANKG and 1 other said thanks
#3 MH81 OFFLINE
Posted March 01, 2016 - 12:44 PM
Good idea.
Amazing how much pressure a scissors jack can create.
  • boyscout862, HANKG and chieffan have said thanks
#4 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted March 01, 2016 - 02:51 PM
Glad someone found a use for those miserable things--I've struggled with one of them pos trying to change a flat and having it flop around and the crank handles are usually some fold up junk who's only goal is to pinch or smash your hand.
I do like your use of a drill to raise it---good idea.
  • boyscout862, WNYTractorTinkerer, HANKG and 2 others have said thanks
#5 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 01, 2016 - 03:30 PM
I've never seen that goofy engagement on a scissor jack before, must be off a Ford vehicle :rolling:  :rolling: :rolling:
I have level stabilizer scissor jacks on the camper. I use an old allen wrench,  chuck it in the drill, slide the bent end in the hole in the jack and then wham, up and down in a heartbeat. :thumbs:
I use my hi lift farm jack for posts, once the chains bites, it's just crank her on up.
#6 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted March 01, 2016 - 03:33 PM
I ruined 2 scissor jacks recently to straighten 1 1/4 galvanized pipe in cattle locking headgates.  But I was using a hydraulic impact, so was putting a lot of pressure on them.  I have more to straighten, and I have 1 remaining scissor jack to do it.
  • HANKG said thank you
#7 HANKG ONLINE
HANKG
  • 6,312 Thanks
  • 3,424 posts
Your eloquent description is balls dead on.
  • Bill 76 said thank you
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted March 01, 2016 - 04:48 PM
Good idea.
I assume you put something large and flat under the jack?
Does anyone on this site besides me drive a Ford with no more than average trouble.
Do you get these jacks at the salvage yard at bulk price?
  • Diesel1050 said thank you
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,464 Thanks
  • 5,768 posts
Posted March 01, 2016 - 05:21 PM
A strap and the tractor bucket does a great job pulling those buggers!!
#10 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted March 01, 2016 - 06:08 PM
Just salvaged from old junked vehicles over the years.  I quickly depleted my pile of them though!   The impact twisted the shafts off at the powered end.  One I might can repair.  The other is done.  There is a small family ran auto junkyard just 2 miles up the road.  I can get as many scissor jacks as I need for cheap.
  • LilysDad said thank you
#11 MH81 OFFLINE
Posted March 01, 2016 - 06:11 PM
Can you put two in there and work a little back and forth between them?
  • olcowhand said thank you
#12 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted March 01, 2016 - 06:13 PM
I could, but when I get around to finishing the job, I'll likely just use one till it dies, then switch to another.  The last remaining one is heavier than either of the first 2, but I couldn't locate it when I did the last pipes.
#13 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted March 01, 2016 - 06:38 PM
  olcowhand , if you have space a small bottle jack will work horizontal as long as the pump is on the bottom.
                                                  Mike
#14 HANKG ONLINE
HANKG
  • 6,312 Thanks
  • 3,424 posts
Posted March 01, 2016 - 07:27 PM
How dare you accuse me of owning a ford !
  • EricR said thank you
#15 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 02, 2016 - 08:12 AM
Nope, just sayin' the jack must be from a Ford, never seen that goofy engagement setup on the end. :D
