LGT 100 Transmission
6 replies to this topic
#1 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted February 29, 2016 - 05:08 PM
 I just wondered if anyone had put a sears transmission in a Ford LGT 100. The sears tranny has a high and low in each gear. This has always been a feature that is needed in the Ford. Sometimes the gap between the gears is to great. I have a 1976 LGT 100 and a sears part tractor. I haven't done any measuring but I did notice the sears drive pulley is on the right side and the Ford is on the left. Just a thought. Probably too much changing and problems to work out.
   Jim
  • boyscout862 and DorthyDuck have said thanks
#2 propane1 ONLINE
propane1
  • 9,470 Thanks
  • 4,398 posts
Posted February 29, 2016 - 06:36 PM
Good idea. If the reverse has a high/low. I have always found the reverse to fast in my lgt 100.
Noel
  • Nicky1 said thank you
#3 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted February 29, 2016 - 07:00 PM
This should be interesting!
  • boyscout862, propane1 and Nicky1 have said thanks
#4 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,797 Thanks
  • 5,095 posts
Posted February 29, 2016 - 07:52 PM
I really like a challenge - and a more useful adaptation,  but with the drive pulleys on opposite sides,  you have your work cut out for you.
I'd probably take the easy way out and find a hydro Ford tractor to put your engine on or get a Deere :mad2:  or Massey :thumbs:  with vari-drive to use as a splitter for between-gear speeds.
I grew up mowing with a Massey 12 gear drive and it had 20 speeds forward and 5 in reverse.
#5 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted March 01, 2016 - 03:40 AM
   Thanks for the input. I figured everyone would think it was a crazy idea.I'm redoing a Cub 108 now and hopefully The Ford will be next. It is my snow plow tractor and is in need of repair. I rebuilt the engine 30 yrs ago and it's smoking bad now... still a standard bore so I have a ways to go.
   The fast reverse has always been a pain, especially when backing a trailer.
  • propane1 said thank you
#6 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted May 04, 2016 - 04:46 PM
I think I have it worked out in my head but sometimes my head is off somewhere else. Just got to get started.
#7 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 05, 2016 - 03:21 AM
Good luck, the axles are not equal length on the ford, the rear frame section is off set for the pulley to exit on the left as this is where the clutch is. If there is some way to flip the shaft in the sears tranny it might work as long as the axles will swap? (Dont think they will if I recall) but if there is way, i would love to see it done, as they really botched that when designing the lgt standard shifts.
