Mystery Kohler K341?
17 replies to this topic
#1 Billy M ONLINE
Billy M
  • 664 Thanks
  • 547 posts
Posted February 29, 2016 - 09:40 AM
It has an electric clutch on the back, and a cut-off shaft sticking out of the front.  It came with the fuel pump an a freshly cleaned carb.  Any idea what this is off of?
  • Traill95 and denasx2 have said thanks
#2 shorty ONLINE
shorty
  • 5,475 Thanks
  • 5,258 posts
Posted February 29, 2016 - 09:51 AM
The coupler on the flywheel reminds me of what New Holland and the early Ariens with the Vickers used. So something from the early 70's.
  • boyscout862 and Billy M have said thanks
#3 Billy M ONLINE
Billy M
  • 664 Thanks
  • 547 posts
Posted February 29, 2016 - 09:59 AM
Thanks Shorty.  That would make sense, as the engine came with the Ariens GT18 I just got.  I've never seen a NH in person, so I couldn't verify.  Is that the electric clutch that was used on those as well?  It's different than the clutches on my other K series Kohlers.
  • 14,800 Thanks
  • 15,495 posts
Posted February 29, 2016 - 10:45 AM
The NH tractor of that era where built by Ariens, just painted a different color.
  • Billy M said thank you
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 29, 2016 - 11:19 AM
I don't think that is a K341, they have 10 head bolts, your picture shows 9 head bolts, could be a K321 - 14hp ???
  • KennyP, Billy M and propane1 have said thanks
#6 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted February 29, 2016 - 11:23 AM
Good catch Doug, The K-241 thru K-321 all use a 9 bolt head. He needs to measure the bore to see what it is or pull the flywheel to see the block stamping.
  • DH1, Billy M and propane1 have said thanks
#7 Billy M ONLINE
Billy M
  • 664 Thanks
  • 547 posts
Posted February 29, 2016 - 11:51 AM
Good to know.  I was just going on what the guy told me.  Honestly, I'll probably never use it...hopefully.  I have enough projects around here at the moment.
TD&H...I am aware of the NH machines, I've just never seen one in person.  I now have 6 Ariens GTs (one parts machine), so I'm pretty familiar with those.  :D
  • DH1 and Texas Deere and Horse have said thanks
#8 diesel nut ONLINE
diesel nut
  • 700 Thanks
  • 425 posts
Posted February 29, 2016 - 12:57 PM
If the tag with the model and spec # is still readable the Kohler website is pretty good about saying what it was originally put in when you use the parts lookup.                       Stewart
#9 shorty ONLINE
shorty
  • 5,475 Thanks
  • 5,258 posts
Posted February 29, 2016 - 01:37 PM
I can't say for sure on the clutch. It has been a while since I worked on an early Ariens. I am sure other manufacturers would have used a similar setup in the same time era.
#10 Billy M ONLINE
Billy M
  • 664 Thanks
  • 547 posts
Posted February 29, 2016 - 02:02 PM
The tag wasn't readable.  I tried that route.  I was hoping someone would recognize the flywheel & clutch setup to identify what it was off of.  I guess I'll have to measure the bore, if I ever get to tearing it down, to identify the HP.
  • propane1 said thank you
#11 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 366 Thanks
  • 500 posts
Posted September 22, 2016 - 09:06 AM
1966-1972 ford LGT 120 engine that can run hydraulic it's the one I have in my tractor
-TC
Edited by pick-to-stone, September 22, 2016 - 09:07 AM.
#12 Billy M ONLINE
Billy M
  • 664 Thanks
  • 547 posts
Posted September 26, 2016 - 11:11 AM
-TC
Thanks TC!  So the output shaft/adapter on the flywheel and the PTO clutch matches what you have on your tractor?  That's great if it does.  At least I know what it goes to now...not that I couldn't make it fit something else.  :D
#13 dodge trucker ONLINE
dodge trucker
  • 2,429 Thanks
  • 3,121 posts
Posted September 30, 2016 - 07:29 PM
no not quite. NH designed and built them originally and then sold the line to Ariens.
#14 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted October 24, 2016 - 03:08 PM
he's incorrect it isn't from a ford I think he meant just the engine model itself was used in a ford
  • shorty said thank you
#15 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted October 24, 2016 - 04:48 PM
Definitely not from a closed side Ford!
