Guess what LF
#1
OFFLINE
Posted February 22, 2016 - 12:31 PM
- WrenchinOnIt and Traill95 have said thanks
#2
OFFLINE
Posted February 22, 2016 - 12:33 PM
- accidentalchild said thank you
#3
OFFLINE
Posted February 22, 2016 - 12:39 PM
#4
ONLINE
Posted February 22, 2016 - 02:41 PM
The engine appears to be a Kohler so 1886. I do see lift bars for a rear attachment in there.
#5
OFFLINE
Posted February 22, 2016 - 03:35 PM
Looks like a Johnson loader.
My guess is 14xx also. Do 1886 have Bolens cast into rear axle??
- WrenchinOnIt and accidentalchild have said thanks
#6
OFFLINE
Posted February 22, 2016 - 04:25 PM
- blackjackjakexxix and accidentalchild have said thanks
#7
OFFLINE
Posted February 22, 2016 - 04:31 PM
Looks to be a 1886-01 - 1886-03 need more photos to really tell what it is. Only 14hp LF it could be is the 1477 that was the only 14hp LF that could come with PS.
- LPBolens and accidentalchild have said thanks
#8
OFFLINE
Posted February 22, 2016 - 06:34 PM
Just to hard to tell,can't see the engine good enough,I also would say Johnson 14 loader
#9
OFFLINE
Posted February 23, 2016 - 11:03 AM
Edited by 1967bolens collector, February 23, 2016 - 11:05 AM.
#10
OFFLINE
Posted February 23, 2016 - 11:20 AM
I saved the first photo and tried zooming in but it's still really hard to tell on the type of engine.
The loader looks like a Johnson.
Yup, the 1886-05 series did which had the Eaton 12 (same as the earlier large frames.) The 1886-06 (HT18) is when Bolens went to the later Sundstrand 15 in the HT18/20 large frames.
Edited by Austen, February 23, 2016 - 11:39 AM.
#11
OFFLINE
Posted February 23, 2016 - 01:08 PM
- Austen and accidentalchild have said thanks
#12
OFFLINE
Posted February 23, 2016 - 01:57 PM
Trans -axle looks like my 1477,, but the fender pan doe's not. and I have no power-steer on a 1972 model .
#13
OFFLINE
Posted February 23, 2016 - 02:17 PM
Me thinks the 1886-01 thru 04 had the Eaton pump, the O5 and O6 the Sundstrand.I saved the first photo and tried zooming in but it's still really hard to tell on the type of engine.
Once power steering became available on a LF was an option all the way thru until the HT23S, the early PS Cessna pump shown here and pretty cool because you don't see them a lot (yes there are NOS NIB owned by members here). Required an proportioning valve installed in the lift/remotes valve body , I believe do to the pressure the Eaton developed and I also believe the small size of the Cessna valve on the PS unit, later model PS like on the HT20-23 had a larger Cessna valve and can be retrofitted to an 1886 without the proportioning valveTrans -axle looks like my 1477,, but the fender pan doe's not. and I have no power-steer on a 1972 model .
Edited by WrenchinOnIt, February 23, 2016 - 02:21 PM.
- blackjackjakexxix, sodisr, Austen and 1 other said thanks
#14
OFFLINE
Posted February 23, 2016 - 06:21 PM
If it's a half decent price u better run because 1250s brining 1400 these days with no loader or ps that will be gone in a heartbeat. Looks like a 1477 to me looks like single cylinder engine
Take the 1 off 1400 and that is what they go for in my parts.
#15
OFFLINE
Posted February 23, 2016 - 07:25 PM
You are very lucky!
Next time you see an 1886, any HT with loader for a good price give me a ring!
THANKS!
