Transmission Make and Model in JD 314
2 replies to this topic
#1 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 29, 2011 - 10:12 AM
Can anyone tell me what model transmission is in the 314. I seem to recall it is a Sandstrund hydro and Dana axle but I don't know any more than that.
Thanks
  • 14,725 Thanks
  • 15,469 posts
Posted April 29, 2011 - 11:11 AM
JDBrian, You are correct, the 314 had the same tranmission as the 140, 300 did prior to the 314 introduction. I hope this helps.
#3 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 29, 2011 - 06:57 PM
Brian
I have always wanted a 140 but have not ever seen one for sale up here. I decided to buy the 314 because it seems to have a lot of similarities to the 140. The frame, steering gear and drive train look very similar. I see you have a lot of 140's. I have a couple of quick questions. I would like to add a second hydraulic circuit to the 314. What JD parts would I need to do this? I know I could do it using a solenoid operated valve and fittings/lines etc but it would be nice to keep it stock. Does a 140 have a float function on the blade lift valve? The 314 does not have float on it's single circuit.
Thanks
Edited by JDBrian, April 29, 2011 - 06:59 PM.
Typo, clarification
