Oh No!
9 replies to this topic
#1 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted February 20, 2016 - 05:53 PM
On other posts of mine, I have been working on a backfire. Had the top off the cargo and cleaning things up. Carb cleaner and air. I blew into an opening in the carb bowl (still on the tractor)and gas blew out in a pressurized stream and something ignited the gas. Melted some wiring and I still have a dead short. The amp Guage pegs about every 30 seconds and then releases. Why does it cycle?
Thanks
#2 mrmr56 OFFLINE
mrmr56
  • 202 Thanks
  • 122 posts
Posted February 20, 2016 - 05:55 PM
It sounds like the automatic resettable circuit breaker is making contact and then breaking again because of an overload.
Edited by mrmr56, February 20, 2016 - 05:56 PM.
  • MH81, Cvans and cootertom have said thanks
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted February 20, 2016 - 06:06 PM
:yeah_that:   Be glad it is doing it's job.    Hope you cure its ills quickly.    Good luck.  Rick
#4 MH81 OFFLINE
Posted February 20, 2016 - 07:25 PM
It can happen in a flash
Glad you werent hurt.
#5 limebuzz ONLINE
limebuzz
  • 1,000 Thanks
  • 976 posts
Posted February 20, 2016 - 07:32 PM
Look for any broken isulation around wires that can ground out. I had this and it was a safety switch. Good luck.
#6 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted February 20, 2016 - 10:32 PM
I will check the two safety switches tomorrow.
Thanks
#7 crossarm OFFLINE
crossarm
  • 58 Thanks
  • 42 posts
Posted February 21, 2016 - 07:30 AM
Might also check voltage regulator
#8 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted February 21, 2016 - 04:26 PM
I don't see a voltage regulator in the wiring diagram I have.
#9 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted February 22, 2016 - 05:45 PM
Looks like I have narrowed it to a white wire going toward the starter area. Need to remove the covers on the front of the engine. I assume the pulley on the end of the crank requires a puller. Am I right?
Thanks
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 03, 2016 - 09:17 AM
More than likely
