Alternative stove burning fuels
7 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted February 20, 2016 - 02:46 AM
i was on Youtube last weekend & got on to oil burning alternatives for stoves & pot bellies so off i ushered to have a go at making 1 of these new beaut things & here is the results of the build
 P7050011.JPG  this is a view inside of the burner stack
a lot of these i was made never had a cap on top but i put 1 on to stop burning the baffle plate in the stove P7050012.JPG
P7050009.JPG  as it is set up in the pot belly in my hut
the 3rd pic shows the steel chalk ring mark i drew on the cast iron plate from a outdoor BBQ which shows the vent or breather holes i drilled 5/8' ,the little stack is 4" steel pipe heavy type for welding
the slotted hole was there ,so i used it as a filler to fill the unit with used oil with a steel funnel & i use a little bit of Methylated spirits to light it with & i just use the stove flutes to control the burn with '
it works really well with very little smoke at all compared to wood burn , but the oil is pretty clean that i'm using though
it burnt for about 2 hrs or bit longer with 3/4 full of oil but would probably burn longer if using heavier type oils
Shane
  • Alc, KennyP and boyscout862 have said thanks
#2 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted February 20, 2016 - 05:13 AM
Pretty simple set up! Thinking about something similar.
  • boyscout862 and holdenboy1960 have said thanks
#3 MH81 OFFLINE
Posted February 20, 2016 - 07:25 AM
One of the big things to overcome is temp v viscosity.
Warmer=thinner=faster flow
Read and pick the best work around for your situation
#4 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted February 20, 2016 - 07:33 AM
Interesting idea. How was your trip? Good Luck, Rick
#5 chieffan ONLINE
  • 10,147 Thanks
  • 6,640 posts
Posted February 20, 2016 - 08:19 AM
Interesting but would need an auto filler.  Larger scale for a larger area like a shop ,more trips to fuel it.  They have furnaces the burn waste oil that are very efficient.  Friend has one in his large truck/tractor repair shop.  Use the waste oil from his shop only and hasn't bought any gas in several years.
#6 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted February 20, 2016 - 08:29 AM
Rick , trip bush is always good Heavenly Quiet cept the noise & time to think a bit
MH81 ,with the thin oil i was burning i was pretty happy with the burn time , but remembering oil of any sort has a LOT of energy for heat so i will run it for a bit this winter coming & see & do a few little alterations & such maybe ,
but i do need a few more breather holes in the flat plate for it to breath a little better i think
 i do have another stove near my hut to replace the baffle in so might do some tests on it as well
Kenny , the hardest part was drilling all the holes in the little stack with the press drill , that's why i decided to cut slots in it , made it quicker & much easier & i can adjust the hole sizes by opening or closing the slot tags a bit if needed
#7 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted February 20, 2016 - 08:33 AM
i did consider a tank above but seemed unsafe to me so just for trial & such i opted to just have a manual fill & also i never had a adjustable inline jet any where close to be found
#8 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted February 27, 2016 - 08:12 AM
UPDATE on this type of system
i decided to make another 1 for the other stove as it dont have a baffle plate in side the plate had burnt out & cracked in half still to cut 1 for it,
with no more said here are some pic's of it
 tis ie the plate cut out & off to size P7100028.JPG the plate i'm using is an outdoor gas BBQ as it is a hot cast & can be welded with mig or stick without to much hassle unlike chilled or tempered cast iron or even a cold cast
 P7100037.JPG is of the stack set ready to weld on
here i did a bit different i welded 4 swirl bars in it but i don't think it made any difference P7100043.JPG , it is welded on P7100045.JPG
the out door camping roast dish (cast iron ) bout 2,1/2" deep for the oil burner tub rectangle shape P7100038.JPG just squeezed into the stove
the stove being used P7120047.JPG & the fire P7120050.JPG i did place a temporary baffle plate in as it needed it to low the drawing a bit because there is no flute in the stove stack only the bottom air adjustable vents
P7120052.JPG i spaced the baffle 1/4 " above the fire stack inside to get it to burn better on the  oil, i  use a bit of metho to light it with
P7120054.JPG this is about 60 to 70 % cleaner than wood burn on a 4 inch stack 6 ft high the dish fan(Run sorry ) for approx 5.1/2 to 6 hrs on 1/2 full unit at roughly 2 turns on the 2 vents ,Stainless Steel Kettle was still hot next morning 6,1/2  hrs later after lighting it
Shane
Edited by holdenboy1960, February 27, 2016 - 08:53 AM.
