synthetic oil in GT's
oil lubrication
7 replies to this topic
#1 WA7PUG OFFLINE
WA7PUG
  • 1 Thanks
  • 6 posts
Posted February 19, 2016 - 08:33 PM
Does anyone know if there is any reason I cannot use a synthetic oil in a JD318? Seems like it might be good for the tractor ....
Thanks! doug
  • 637Yeoman said thank you
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted February 19, 2016 - 08:48 PM
You can use it.
  • boyscout862, 637Yeoman and WA7PUG have said thanks
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted February 19, 2016 - 09:05 PM
I seem to remember another post or two about this same issue, maybe someone can point you to that. If you are changing from standard to synthetic you will want to flush the original oil out pretty well. Changing oil can sometimes cause your seals to leak. Good luck.
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted February 20, 2016 - 12:04 AM
If it is an older model it can be best to use synthetic diesel oil. It contains more zinc that really isn't in new gas oil because of the catalytic converters in newer automobiles.
  • boyscout862, MolonLabe and WA7PUG have said thanks
#5 karel OFFLINE
karel
  • 2,225 Thanks
  • 1,443 posts
Posted February 20, 2016 - 02:23 AM
I use synthetic oil in all my machines. And for many years. I like it. it gives more power due to less friction.
  • boyscout862, Bolens800uk and WA7PUG have said thanks
#6 JDBrian OFFLINE
  • 9,635 Thanks
  • 14,156 posts
Posted February 20, 2016 - 08:34 AM
Amsoil makes a synthetic replacement for SAE30. It's spec'd to replace 30 or 10W30.
  • limebuzz and WA7PUG have said thanks
#7 WA7PUG OFFLINE
WA7PUG
  • 1 Thanks
  • 6 posts
Posted February 25, 2016 - 12:27 AM
Guys, thank you for your input ... my 318 is still my workhorse as a tractor - don't even have a mower deck for it because I use it for everything else (have a D104 to mow with), so I really appreciate your help.
Thank you! dj
#8 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted February 25, 2016 - 08:19 AM
I've used synthetic oil in all of my vehicles, GT's, generators, snowblowers....etc for as long as I can remember. I also add a couple of ounces of Lucas Oil Break In Additive to boost the zinc content. It either works great or I've been incredibly lucky.
  • WA7PUG said thank you
Also tagged with one or more of these keywords: oil, lubrication
