68 sears suburban drive belt?
sears suburban belt drive
4 replies to this topic
#1 68searssuburban OFFLINE
68searssuburban
  • 6 Thanks
  • 29 posts
Posted February 19, 2016 - 08:26 PM
i have a 68 sears suburban 12 that i would like to change the drive belt on but i have no numbers or literature on the belt. the belt adjustment pulley has already been moved all the way so im not even sure if it is the proper belt on it or not. sears numbers would be fine as i do have the conversion table somewhere. thanks
#2 Bolens 1000 ONLINE
  • 14,898 Thanks
  • 18,099 posts
Posted February 19, 2016 - 08:36 PM
I stock the one you need, these are the best quality you can buy in the industry and USA made
http://bolenspartsan...4h-6774h-84352/
  • MH81, boyscout862 and 6mikey7 have said thanks
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted February 19, 2016 - 08:47 PM
5l810, 81" Bolens 1000 does have really good ones
#4 68searssuburban OFFLINE
68searssuburban
  • 6 Thanks
  • 29 posts
Posted February 19, 2016 - 09:09 PM
thanks for the help and the link to your store. ill order one up shortly. looks like it is reasonably priced too.
#5 JiminRI OFFLINE
JiminRI
  • 91 Thanks
  • 80 posts
Posted February 20, 2016 - 09:23 PM
The Suburban 12 (model 917.25630, circa 1970) Owner's Manual calls for a 6474H which is a 5/8 inch by 81 inch V-Belt.
The 1969 Suburban Super 12 (model 917.25311) Owner's Manual calls for the same belt.
The 1973 ST-16 (model 917.25740) Owner's Manual calls for the same belt - so it appears all the single cylinder Suburban's may have used the same belt. The 1973 Twin cylinder Onan SS-16 (model 917.25751) used 2692R which is a 5/8 inch by 84 inch V-Belt.
JiminRI
  • 6mikey7 said thank you
