Can I take the starter off?
7 replies to this topic
#1 DanP OFFLINE
DanP
  • 324 Thanks
  • 485 posts
Posted February 19, 2016 - 09:13 AM
I have a later model Briggs motor with electric start. I want to use it as a non electric start. Can I just take the starter off or do I have to do something with the alternator?
  • vewatodo said thank you
#2 olcowhand ONLINE
  • 41,276 Thanks
  • 31,449 posts
Posted February 19, 2016 - 09:42 AM
If no need for a charging system, just unhook the leads to the stator.
  • DanP said thank you
#3 DougT OFFLINE
DougT
    Dog Approved
  • 6,931 Thanks
  • 4,997 posts
Posted February 19, 2016 - 10:04 AM
The charging system should work regardless if there's a starter. You're going to need power to energize the fuel shut off in the carb if it has it?? Might be better to post the engine model.
  • MH81 and DanP have said thanks
#4 chieffan ONLINE
  • 10,201 Thanks
  • 6,659 posts
Posted February 19, 2016 - 02:01 PM
No reason to remove the starter either.  Just don't use it.  If you don't have a battery you don't need the charging system either.  A fuel shut off might be a different situation though.
Edited by chieffan, February 19, 2016 - 02:02 PM.
#5 MiCarl ONLINE
MiCarl
  • 2,054 Thanks
  • 1,058 posts
Posted February 19, 2016 - 02:58 PM
If you're going to remove the battery disconnect the regulator/rectifier too so you don't cook it.
#6 glgrumpy OFFLINE
  • 8,622 Thanks
  • 7,926 posts
Posted February 19, 2016 - 05:42 PM
So, how you going to start it then??  Rope pulley on flywheel?  Manual pull starter, but in the tin on blower housing?  Push it in gear?  Not sure why one would want to do by hand, when can use key???   As noted, with no batt should run with magneto they have and can just leave the parts on and not have hooked up.
#7 DanP OFFLINE
DanP
  • 324 Thanks
  • 485 posts
Posted February 22, 2016 - 08:58 AM
I want to put it on a garden tiller and I don't want a battery on it. I would have to build a holder and it only gets used spring and fall and those batteries don't last very long. I also don't want that weight. The motor has a recoil on it so starting is no problem. I will have to check out the fuel shut off on the carb.
  • olcowhand said thank you
#8 olcowhand ONLINE
  • 41,276 Thanks
  • 31,449 posts
Posted February 22, 2016 - 09:15 AM
You can just unscrew the fuel shutoff if equipped, and either grind off the tip, or ship it off with a pair of side cutters.
