H14 resurrection
18 replies to this topic
#1 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 19, 2016 - 12:51 AM
Well after I got the new project home yesterday I wasted no time to start working on it. I already had a correct hh140 damn near ready to go for it.
I started by pretty much building a wiring harness from scratch. Really helps when I got the factory bolens diagrams and another tractor with the same harness.
I then had to swap cables as the original ones had been cut for an engine swap.
Today was spent running around trying to find the correct 12pt engine mounting bolts, couldn't find em so I used Allen heads instead.
Got the motor mounted,hooked up the cables and three a battery In choked it and hit the key. She lit up and runs decent.
Just have a few little issues to get worked out, also have to run wire for the lights and figure out the plugs for the stator and the rectifier, tractor currently won't turn off with the key. The motor has some sort of apparatus on the shroud where the wires are and the plugs don't match, I'll get a pic tomorrow
All in all not too bad for a few hours of work.
  • Bolens 1000, LPBolens, Alc and 9 others have said thanks
#2 boyscout862 ONLINE
  • 15261 Thanks
  • 10024 posts
Posted February 19, 2016 - 07:12 AM
Beautifull. I especially like that seat and the garage. Good Luck, Rick
#3 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted February 19, 2016 - 07:13 AM
Pretty quick turnaround! Looks like it's in overall good condition.
#4 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 19, 2016 - 08:23 AM
Didnt take you long at all , nice work!
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted February 19, 2016 - 09:37 AM
Good looking machine
#6 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 19, 2016 - 09:49 AM
Wow,talk about wasteing no time,good job
#7 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted February 19, 2016 - 11:11 AM
Looking great...   I was going to ask you a ??? about adjusting the hydro While it was all apart...  But I see you wasted no time buttoning it all back up...  I need to adjust my hydro lever and I don't want to strip the panels all down to the tubes..
  Anyway,,,,,    nice job....
#8 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 19, 2016 - 11:35 AM
Yeah the tractor isn't in awesome shape but it's not terrible either. Gonna giving a bath today and probably beat some dents and wrinkles out if the sheet metal.
#9 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted February 19, 2016 - 07:20 PM
Looks great!
#10 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 19, 2016 - 08:50 PM
Anyone got the diagram to tie this back to the tractors wiring?
Tractor doesn't currently charge and won't shut off with the key.
#11 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 20, 2016 - 09:07 PM
Got all the wiring finished up. It now charges and shuts off with the key. Not too bad for a guy that has limited wiring skills. Also got the lights wired just need some tail lights now. Also added all the pto parts as they were missing. And went and dug out a deck and all the correct mounting parts. Also took the easy chair off and put a regular seat on it.
  • LPBolens, blackjackjakexxix, AA Hayes and 1 other said thanks
#12 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted February 20, 2016 - 10:06 PM
Who makes that back blade that is on the sleeve hitch? I would love a back blade for one of my tube frames, even more so for my ht20 but finding a 3 pt hitch has been very hard.
Edited by AA Hayes, February 20, 2016 - 10:06 PM.
#13 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 20, 2016 - 10:31 PM
It's a brinly
#14 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 525 Thanks
  • 474 posts
Posted February 22, 2016 - 06:01 PM
Did some other brinly activities this weekend too. Deck and hardware is ready to go too.
  • LPBolens, blackjackjakexxix, 29 Chev and 1 other said thanks
#15 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 23, 2016 - 02:17 PM
Lookin for a set of them fmc real wheel weights I have a front set for the ht20D when I put the trencher on it
