How Not To End Your Day Blowing Snow
21 replies to this topic
#1 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted February 18, 2016 - 01:58 PM
Was blowing snow last Saturday with my homemade two stage blower that I had recently modified to try and simplify the fan speed reduction and things did not end well. With the modification I had done http://gardentractor...uction-upgrade/  I had created an angled PTO which was possibly too steep and as a result the PTO shaft came off the blower, whipped and broke the end of the splined shaft off the front of the PTO on my 1050.  I have put the PTO off my other 1050 on and hooked up the backup snow caster until I figure out how to reduce the angle of the snow blower PTO shaft.
  • olcowhand, LPBolens, Alc and 6 others have said thanks
#2 BolensChrisUK OFFLINE
BolensChrisUK
  • 603 Thanks
  • 263 posts
Posted February 18, 2016 - 02:19 PM
Ouch! That looks painful
Hope you can find another shaft
  • boyscout862 and 29 Chev have said thanks
#3 101 senior ONLINE
101 senior
  • 626 Thanks
  • 601 posts
Posted February 18, 2016 - 03:15 PM
Hope your alright.
#4 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 18, 2016 - 03:47 PM
Stew,that's pretty ugly,how's the snow caster look
  • 29 Chev said thank you
#5 petrj6 OFFLINE
petrj6
  • 4097 Thanks
  • 2370 posts
Posted February 18, 2016 - 04:31 PM
   will any tubeframe pto work ?  I have a front pto for a bolens 750 here I have not use for.  you want it it is yours just pay the ship.
        Pete
  • MH81 and 29 Chev have said thanks
#6 jabelman OFFLINE
jabelman
  • 2401 Thanks
  • 1668 posts
Posted February 18, 2016 - 05:07 PM
I don't think jb weld is going to fix that one
  • LPBolens and 29 Chev have said thanks
#7 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 18, 2016 - 05:28 PM
Whoops!
Edited by wilberj, February 18, 2016 - 05:29 PM.
#8 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted February 18, 2016 - 07:02 PM
It hurt my pride more than anything - I believe there is one on its way to me in the mail
Hope your alright.
I am fine except for my pride
The snow blower is ok other than I have to come up with a new modification to reduce the angle the shaft works on.  Now you know why I needed another shaft - hopefully it will show up next week and by then I will have started on the modifications as I think I have come up with a plan
        Pete
I believe the 750 is different as it uses a keyway instead of a spline inside the pulley and the shaft is shorter as they only use one belt  - thanks for the offer.
It would be optimistic to think JB weld would stand up in that application.  I will probably try welding the broken piece back on someday when it warms up and see what happens - worst case scenario it would break again.
Whoops!
 That was one of the words I used when it happened.
  • MH81, LPBolens and blackjackjakexxix have said thanks
#9 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted February 18, 2016 - 07:36 PM
Good luck getting her fixed up, luckily you had another PTO you could "borrow".
#10 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 19098 Thanks
  • 11900 posts
Posted February 18, 2016 - 07:41 PM
I bet you would never have this trouble with a Murray.
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 18, 2016 - 07:43 PM
Whats a Murray?  ........:poke:
  • blackjackjakexxix, LilysDad, Little Irish Men and 3 others have said thanks
#12 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted February 18, 2016 - 08:03 PM
Perhaps not but would Murray move as much snow in an hour as a Bolens on a very cold day (-3 degrees F when that happened) for little pay other than a couple of shots (of grease) and a tank of gas?
  • propane1 and AA Hayes have said thanks
#13 propane1 ONLINE
propane1
  • 13642 Thanks
  • 6004 posts
Posted February 18, 2016 - 08:07 PM
That's nasty. Sorry to see that. Hope you can get a part.
Noel
#14 propane1 ONLINE
propane1
  • 13642 Thanks
  • 6004 posts
Posted February 18, 2016 - 09:22 PM
Is that spline the same as a rear pto on a farm tractor.?
Noel
#15 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted February 18, 2016 - 09:29 PM
Noel
No I don't believe so.  It is a six spline with an O.D. of .750" if memory serves me correctly.  I repaired the splines in the U joint yoke that attaches to it a couple of years ago.  http://gardentractor...s-tube-fra-r204
  • MH81 and propane1 have said thanks
