I saw their add in Farm Collector mag. and like the idea, think it would make greasing my stuff as well as the farm equipment a lot easier, what are your thoughts.
Any one try LocknLube grease gun couplers?
#2
ONLINE
Posted February 18, 2016 - 06:12 AM
That looks neat! Let us know how it works!
- adamjd200 said thank you
#3
ONLINE
Posted February 18, 2016 - 06:20 AM
Nice idea ! Geared more for equipment then the guy ( or gal ) in a service station doing mostly cars & light trucks , the ones with grease fittings anyway lol . Not sure if it would fit into some of the recessed grease fittings on the backhoes here at work .
- boyscout862 and adamjd200 have said thanks
#4
OFFLINE
Posted February 18, 2016 - 06:59 AM
#5
ONLINE
Posted February 18, 2016 - 08:17 AM
I have found a lot of time when the coupler leaks grease or won't stay on it is because the coupler has come loose, or unscrewed. I tighten it back up and it works again. Most of the time I use an air grease gun with steel tube from gun to zerk, but there are a couple zerks that this set up will not work. If this item work out I would buy one though and go back to more portability and a hand gun with rubber hose. Please keep us posted.
#6
OFFLINE
Posted February 18, 2016 - 09:39 AM
What will they think of next?
#7
OFFLINE
Posted February 18, 2016 - 10:54 AM
That looks like a good setup. Would be great around our farm equipment.
Let us know how you like it.
#8
OFFLINE
I'm thinking about getting one, some of the fittings on some of the equipment are in an odd spot.
#9
OFFLINE
Posted February 18, 2016 - 11:43 AM
Just found one local for $20 bucks. Think I will try it.
Reviews say it is a bit bigger than a normal end and does not fit in all places
I think a stub hose with a regular end and a grease fitting on the other end will solve that issue.
Let you now when we get it.
- Alc said thank you
#10
OFFLINE
Posted February 18, 2016 - 01:42 PM
I've always had two 18" hoses joined w/ a 1/8" coupling on the gun. That way if I'm on the floor I can lay the gun down to pump it of if standing I can either hold the gun on my hip or on some surface near the zerk to pump it. That way I always have a free hand to hold the coupler aligned w/ the zerk. Did it that way for a lot of years on the gravel refineries.
Mike
Edited by ol' stonebreaker, February 18, 2016 - 01:44 PM.
- Alc and shorty have said thanks
#11
OFFLINE
Posted February 18, 2016 - 01:59 PM
Nothing like plenty of hose on a grease gun. Sure can make the job easier.
#12
OFFLINE
Posted February 18, 2016 - 07:27 PM
I have one and so far it works good but some times its just to long to get into fitting
- KennyP and Cat385B have said thanks
#13
OFFLINE
Posted February 24, 2016 - 05:10 PM
Well, I went and ordered one off the website (only local place that has them is a dealer I don't deal with much), gonna put this one on one of the guns we use on the equipment, if I like it I'll probably get on for the gun for the truck and trailer.
#14
OFFLINE
Posted February 28, 2016 - 01:44 PM
I like it but will continue to curse about holding fitting tight on zerk to grease my truck!
#15
OFFLINE
Posted March 08, 2016 - 05:34 PM
Got it installed on a grease gun today and greased the front spindles on my Case210 just to try it out, I love it, it is a little bit bigger but for 99.9% of my stuff it will work great, I have a mini pistol-grip grease gun with a standard coupler for those fittings.
- limebuzz, Alc and MFDAC have said thanks
