A little help please..
4 replies to this topic
#1 JimD OFFLINE
JimD
  • 682 Thanks
  • 486 posts
Posted February 17, 2016 - 09:18 PM
I am in need of a new ignition switch for a Tecumseh OH140 engine off a Craftsman tractor. I was given this engine and don't know what model tractor it came from other than it was a Craftsman older model. It has a solid state ignition if that helps. Anyone have any idea what switch will work?
Thanks,
Jim
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted February 17, 2016 - 09:56 PM
Jim, I don't have a number but you need to make sure the switch you use has an M terminal on the back and that has to go to the kill wire. It has to have a G term that needs to go to ground. Those 2 should show continuity when the switch is off and open when on. That is the only post that should show contact to the M term in any position. I'd even test a new switch just to make sure. Those ignitions are sensitive enough that they don't need an errant switch.
  • JimD, Gtractor, MH81 and 2 others have said thanks
#3 MH81 OFFLINE
Posted February 17, 2016 - 09:59 PM
Almost any Teccy based unit's switch
Never, never apply power to the cdi. It is ground out to shut down.
If that doesn't make sense, PM me.
  • JimD, boyscout862 and propane1 have said thanks
#4 JiminRI OFFLINE
JiminRI
  • 91 Thanks
  • 80 posts
Posted February 18, 2016 - 02:36 PM
The Sears 14/6 had a Tecumseh OH140 (14 hp, 388 cc, 1 cylinder). The switch number from that owner's manual is 4406R.
Here is one source for $10.39 including shipping.
http://www.amazon.co...1/dp/B001UL3E74
And another for $9.32 (shipping TBD) http://www.jthomaspa...h_4406R_JT-9821
Both include keys.
See switch diagram (from first link) below.
Good luck,
JiminRI
  • JimD, MH81 and TAHOE have said thanks
#5 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted February 19, 2016 - 08:20 AM
Most NAPA's carry them too, but I don't remember the stock #
Edited by TAHOE, February 19, 2016 - 08:21 AM.
