ford lgt 165
36 replies to this topic
#31 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 09:29 PM
That's true. I plan on weighting it out. The 212 in the pic I posted has about 70lbs of liquid per tire and not sure what the weights weigh. And I plan on doing the same to the Ford I want to find some cast weight or just some 1" plate and make some
  • janaxe1 said thank you
#32 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted February 22, 2016 - 04:04 AM
The pedals work fine for plowing, and reverse is way easier when you slightly extend the pedal's length by 1/2" or so. I used the pedal from my 82 LGT 165 on my 72 LGT 125 and it is perfect perfect!!! On the 83 I made a brand new on complete that was longer on the treadle and a bit taller so when fully depressed the treadle did not touch the floor pan.
They are both are a dream to operate.
  • Chopperhed said thank you
#33 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted April 13, 2016 - 01:16 PM
Skyrydr2 could you post some pictures of the pedal modifications you did to your tractor
#34 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 14, 2016 - 03:33 AM
I'll try and get a few pics today, might be later though, getting a new water softener installed with a reverse osmosis filtration unit for drinking water supply.
#35 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted April 14, 2016 - 08:15 AM
Cool no rush when you get time
#36 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 18, 2016 - 07:21 PM
Length is 5" and the foot pad is about 2" the last pic is my 72 LGT 125 with the pedal off my 82 165.
  • glenford7502 said thank you
#37 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted April 21, 2016 - 12:10 AM
Very cool thank you
