ford lgt 165
36 replies to this topic
#16 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 07:22 AM
A Motorola droid maxx
#17 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 07:23 AM
I'll try that thanks kenny
#18 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 09:50 AM
This should be a picture of my new ford and my 212 let me know if it works
#19 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 09:53 AM
Me and my brother were out fixing my driveway a little yesterday. Was also wondering if anyone had any pictures of how the gas tank is supposed to be attached onthat ford mine just floats around in there right now
#20 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted February 21, 2016 - 10:19 AM
Pics look good! I can check mine out here in a bit, but some of the other Ford owners will have an answer by then!
I found a pic showing one of the nylon straps. The other side is the same. Some real long zip ties would hold it in there. These go all the way around the tank and over the two  upper braces.
Edited by KennyP, February 21, 2016 - 10:37 AM.
  • glenford7502 said thank you
#21 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,138 posts
Posted February 21, 2016 - 10:41 AM
Found this one:
  • KennyP and glenford7502 have said thanks
#22 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 01:36 PM
Cool I got some big zip ties thanks for the help I appreciate it Kenny. That hydro lift is way better than lifting by hand. Glad I check the rear end it was like three inches low on hydro.
#23 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted February 21, 2016 - 01:51 PM
Cat got the better pic for ya!
#24 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 03:32 PM
Right thanks cat
#25 TomLGT195 OFFLINE
TomLGT195
  • 4,045 Thanks
  • 2,898 posts
Posted February 21, 2016 - 05:57 PM
Do you have sides for the front? They help with airflow to keep engine cool. What is the handle with yello grip for? 165's are all hydro. Is it hooked up to the brake or the lift? it looks in good shape though. Good luck!
#26 propane1 ONLINE
propane1
  • 9,434 Thanks
  • 4,377 posts
Posted February 21, 2016 - 07:30 PM
The yellow handle is for backing up, I bet. Reverse is normally hard to use on this tractor with the foot pedal. This would help by pulling on the handle , when needed.
Noel
  • TomLGT195 said thank you
#27 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 07:33 PM
The yellow handle is welded to the hydro pedals(I'll take pictures tomorrow) and I do have the side panels they need some work . A couple of the threaded pieces that pin in to the bottom are gone and I have to make some new poly pieces for the other ones. Other than that they are in pretty nic shape.
  • KennyP and TomLGT195 have said thanks
#28 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted February 21, 2016 - 07:37 PM
Does work good for backing up
  • KennyP and propane1 have said thanks
#29 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted February 21, 2016 - 07:52 PM
Check out Ace hardware for the poly pieces. They might have them.
On the pedal, you can shorten the rod some to help with Reverse. But the handle would be nice for plowing if you had to sit more to the left for traction.
#30 TomLGT195 OFFLINE
TomLGT195
  • 4,045 Thanks
  • 2,898 posts
Posted February 21, 2016 - 08:02 PM
That does sound like it might help when plowing. I've thought that keeping my foot on the pedal might be hard.
