Got a MF RER Today!!
18 replies to this topic
#16 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 29, 2011 - 07:19 PM
Ok, you're timing for decals sounds about right, for his pace, and my timing too.
I'll let you know.
  • Stoneman said thank you
#17 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted April 29, 2011 - 09:07 PM
The serial number is 1870700079, i think it's a 1974. I got the engine off and this is what i found
motor 001.jpg Obviously my briggs came in handy!
The whole cylinder is nothing but rust and crud, I haven't gotton to look at the bottom end but i'm pretty sure that it's junk as well. I also noticed that the model number on the engine says v60 which makes it a 6hp instead of an 8hp, the mounting holes on the massey looked like someone re-drilled them too.
#18 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 29, 2011 - 10:35 PM
Nice save, you have a great little project candidate there! Also looking forward to the updates.
#19 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted May 02, 2011 - 08:18 AM
If you "have to" replace the steering wheel stub shaft, you may find that the splines match many auto steering wheel spline patterns. Because the tractor has a hollow steering tube, and cars have a solid one... you could make a very nice repair by turning, say a 6" length of the auto shaft so that it has a tenon pin. The pin will slip into the tractor shaft with "V" beveled edges. Now just weld it in place and grind flush.
For removal, I have found that a large bearing separator under the wheel hub, with a puller bolted to that does wonders. You need to watch the shaft, it can mushroom on you and ruin it. I had made a "plug" on my lathe with a center hole that fit into the shaft and kept the puller in place. It made it pop off nice and easy.
