Kwik way backhoe on a large frame
18 replies to this topic
#1 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 17, 2016 - 12:17 AM
I could get a Kwik way 7ft hoe but never seen on a ht20 an now mounts on a cat0 3pt. Did these exsist
  • Bolens 1000 said thank you
#2 Cvans OFFLINE
  • 9625 Thanks
  • 7319 posts
Posted February 17, 2016 - 12:28 AM
If your talking digging depth a 7 ft. hoe sounds big for a garden tractor.
Edited by Cvans, February 17, 2016 - 12:29 AM.
#3 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 17, 2016 - 06:26 AM
Sounds like a little to much for a HT20.
#4 Talntedmrgreen OFFLINE
  • 3369 Thanks
  • 2369 posts
Posted February 17, 2016 - 08:11 AM
KwikWay makes a nice SGT/SCUT sized BH.  I've seen variations of it on many different brand machines.  It has a 6.5' digging depth.  Unit weighs around 700lbs, however it is NOT a 3pt style.  It utilizes a full length subframe and pins to the tractor frame or 3pt carriage.
http://www.mytractor...=1&d=1402773677
  • olcowhand, LPBolens, Alc and 5 others have said thanks
#5 tractorskipper OFFLINE
tractorskipper
  • 1217 Thanks
  • 727 posts
Posted February 17, 2016 - 11:02 AM
I have a hoe about that size (6.5' digging depth) on a JD 2320 CUT.  In my opinion, a hoe that size on anything smaller would be useless, at least in the ground conditions around here.  Maybe work OK in sand.
#6 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 17, 2016 - 01:14 PM
A Johnson Model 14, which is intended for GT's like the Bolens Large Frames, has a digging depth of 6'. Not sure an additional 6" of digging depth makes that much of a difference in whether it will work or not on a Large Frame. And not that one of the pics above shows the BH on the back of a 400 series JD, a GT comparable in size and power to a Large Frame.
#7 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 17, 2016 - 02:46 PM
Well sum1 made it 3pt I was going to fad a sub frame to make it I wouldn't want it on the 3pt but I just didn't know if they were offered on a LF or not an if the loader digs 6ft the why did the offer the Brantly ld6 for them I don't see the difference
#8 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 17, 2016 - 02:54 PM
  • olcowhand said thank you
#9 Talntedmrgreen OFFLINE
  • 3369 Thanks
  • 2369 posts
Posted February 17, 2016 - 07:55 PM
I like it!
#10 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 17, 2016 - 08:06 PM
Well I made the deal on it I wish it was a ld6 Brantly but I get the hoe 2 different buckets and a sec set of cylinders all rebuilt there's no welds on the hoe but the 3pt rig sum1 put on there I think 1600 is great
  • LPBolens and Alc have said thanks
#11 Cvans OFFLINE
  • 9625 Thanks
  • 7319 posts
Posted February 18, 2016 - 12:01 PM
Good luck with your hoe. Hope you get a lot of good use out of it.  :thumbs:
#12 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 18, 2016 - 05:00 PM
Yea I can't wait to get it home an mounted
  • Cvans said thank you
#13 Talntedmrgreen OFFLINE
  • 3369 Thanks
  • 2369 posts
Posted February 19, 2016 - 06:08 AM
Yeah you did real well.
#14 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted February 19, 2016 - 06:22 AM
Looks nice !  Will you make it a permanent or some way to get it off form time to time . Looks like most GT's 3 point wouldn't even be able to  lift it  .
#15 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted February 19, 2016 - 09:06 AM
I stumbled on this , not for a GT but might give you some ideas
http://www.tractorby...own-custom.html
