1) I am missing the following Parts Lists. If you have them and can either scan them and send them to me electronically, or make hard copies to mail to me, or are willing to send an original to me on loan, post in this thread so I and others will know that that need has been fulfilled.
855-01 & 855-02 (G9)
1054-02
1254-02
1255-02 (G12)
1256-03
1656-04 (H16)
2) If you have a computer, a printer, some basic familiarity with Excel 2007 or some other version, and some time, I could use some help in proofreading the Excel files that are created by conversion from the scanned PDF files. This is how it would work. I would send the original PDF file and the matching Excel file to you. You would then print out the PDF file (or view it on a split screen if you prefer). Then compare it to what the Excel file shows, particularly the Part Numbers. What I am seeing is that if the quality of the PDF scan is a little off, sometimes the conversion will do things like make an 8 a 6, or vice versa. Or the leading 1 in the Part Number will show up as a 7. So you would basically be looking for typos and fixing them, then sending the corrected Excel file back. I won't send you anything that looks too terrible; I will do those myself.
Edited by LPBolens, February 17, 2016 - 09:11 PM.
