Suggestions For Removal Of a Seized Briggs Flywheel
26 replies to this topic
#16 DougT OFFLINE
DougT
    Dog Approved
  • 6,849 Thanks
  • 4,952 posts
Posted February 17, 2016 - 12:05 PM
It's always a good idea to have the nut on the crankshaft when pulling the flywheel. Sometimes the force these come off with is amazing. You'd swear they were shot out of a cannon when they go flying!
  • olcowhand and WNYTractorTinkerer have said thanks
#17 olcowhand OFFLINE
  • 40,349 Thanks
  • 31,170 posts
Posted February 17, 2016 - 03:08 PM
Yes, and when they "pop" you'll swear you just busted something to heck!
  • DougT said thank you
#18 drbish OFFLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted February 17, 2016 - 05:47 PM
If you have some help,with pressure on the flywheel.I have had someone hold the engine with the flywheel up and then used a hammer,the weight of the motor helps for it to come off.
#19 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 17, 2016 - 08:44 PM
These can be tough buggers, Here is picture proof.
#20 chieffan OFFLINE
  • 9,559 Thanks
  • 6,404 posts
Posted February 20, 2016 - 01:41 PM
We got it off but took a lot of pressure on the puller.  It wanted to tip to the side so held it upright with a big crescent wrench.  tightened the puller bolt with a 1/2" breaker bar with flywheel locked.  Smacked the puller bolt with a 3 lb hammer.  Took three tries at it but it popped loose.
Thanks for the advise.  Will remember that for next time.  This was one of the toughest ones I have ran into.
#21 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 20, 2016 - 04:05 PM
My puller bar is permantly bent :D Glad you got it off! Even though you might want to use anti-seize when putting it together, don't! The key on these heavy flywheels are only for alignment.
Edited by larrybl, February 20, 2016 - 04:07 PM.
  • chieffan said thank you
#22 chieffan OFFLINE
  • 9,559 Thanks
  • 6,404 posts
Posted February 21, 2016 - 06:24 PM
Did not use anti seize and tightened it down with an impact.
#23 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 21, 2016 - 06:43 PM
Just removed mine, Post #88 here http://gardentractor...-hulk-ii/page-6
#24 chieffan OFFLINE
  • 9,559 Thanks
  • 6,404 posts
Posted March 06, 2016 - 10:58 AM
I have heard and my boy has also not to use an impact on a puller.  To big a chance of damaging the extra fine threads on the bolt.
We all have done it including me and I have one puller the bolt turns real hard on now.  Chalk up one puller.
#25 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted March 06, 2016 - 02:07 PM
I guess that is why I have went through so many pullers. And here I thought it was the cheep HF tools :hitting_self_roller:
#26 DougT OFFLINE
DougT
    Dog Approved
  • 6,849 Thanks
  • 4,952 posts
Posted March 06, 2016 - 03:11 PM
My opinion of the HF pullers is that the screw is coarse thread and the surfaces rough. I've never seen one with as fine of thread as one of the top brand ones. The more threads per inch, the greater pulling power.  Whatever you use, don't forget to oil the threads of the puller.
  • jimmy G said thank you
#27 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted March 06, 2016 - 04:23 PM
I've not had the threads mess up, rather I have warp / bent the thick bar.
