February's PK Project
21 replies to this topic
#1 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 16, 2016 - 07:03 PM
Hi all, well here's the February project pictures and hint so what is it, its pretty easy I'm sure it5 won't take ;long at all here's the first couple of photos
  • Gtractor and cleolr60 have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
Posted February 16, 2016 - 07:10 PM
Buddy seat for the 3 point?
  • KennyP and MNGB have said thanks
#3 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 16, 2016 - 07:12 PM
No not a buddy seat :dancingbanana:
#4 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Snow plow mount?
  • MNGB said thank you
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 16, 2016 - 07:17 PM
Belly blade
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
Posted February 16, 2016 - 07:31 PM
But think of the distance you could launch someone if you hit a bump while in road gear!
  • KennyP, shorty and MNGB have said thanks
#7 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted February 16, 2016 - 07:59 PM
This has to be why no one rides with you.. 😊
#8 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 16, 2016 - 08:03 PM
Belly blade
We have a winner :wave: :good_job: :dancingbanana:
A couple more pics of todays work.
  • Gtractor, Alc, CRFarnsworth and 1 other said thanks
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted February 17, 2016 - 12:38 PM
Giving me some ideas
#10 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 17, 2016 - 06:44 PM
Hi all, made progress on the mid mount blade today, did a trial fit up and its a go tried the lift and its good, working out the hydraulic angling mounts which is not to far away
.HPIM2351.JPG HPIM2352.JPG HPIM2353.JPG HPIM2354.JPG HPIM2355.JPG HPIM2357.JPG HPIM2358.JPG HPIM2359.JPG HPIM2360.JPG
Edited by MNGB, February 17, 2016 - 06:45 PM.
  • KennyP, shorty and Genem have said thanks
#11 icpik OFFLINE
icpik
  • 23 Thanks
  • 40 posts
Posted February 17, 2016 - 07:38 PM
Appears your horizontal angle will be limited to 15 degrees or less? And a fixed vertical angle on the blade?  That would be difficult to make adjustable.
Don Hayes
#12 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 17, 2016 - 09:59 PM
Hi, yes that's all the travel that's possible with a 4" stroke cylinder and angling is limited by the blade hitting the rear tires, there is limited  vertical adjustments  via a couple of bolts at the back of the blade attach mount, but once the blade is set to cut well it really isn't a needed thing, I have a couple of other mid mt blades and I like how they work and this one will work also. One thing I would like but don't want to get into the complications of doing it and that would be to have have horizontal / vertical control.
#13 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 18, 2016 - 06:47 PM
Hi all, worked on the blade today and made good progress, pretty much have the hitch done, got the angling cylinder mts completed and installed, the hydraulic cylinder and hoses and tried it and it works. This blade is from my Suburban and its 44" wide  my friend is going to bend me up one just like it but 54" wide  when I get it it will be to fabricate the mount and a cutting edge for it. Tomorrow it'll come off the tractor and go to the paint room.
Edited by MNGB, February 18, 2016 - 06:48 PM.
#14 MNGB ONLINE
MNGB
  • 2,628 Thanks
  • 1,573 posts
Posted February 21, 2016 - 05:03 PM
Got the frame parts painted and assembled tomorrow will install it using the 44" blade until the new 54" one is completed, while I was waiting for the paint to cure I made up an electrical switch box and connector to power the sprayers and other 12 v powered things, I usede a wall switch box made a flat cover and mounted a lever switch and a circuit breaker in the box wires it with 14 gauge wire to connect to the battery and to a trailer 4 pin connector (have this set up on my other GT's and its handy)
HPIM2365.JPG HPIM2366.JPG HPIM2367.JPG HPIM2369.JPG HPIM2370.JPG HPIM2371.JPG
#15 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
Posted February 21, 2016 - 06:09 PM
That is getting to be one well equipped tractor.
