Picked up a John Deere 318
john deere 318
24 replies to this topic
#16 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted February 20, 2016 - 04:55 PM
Pulled the cam and lifters. Also thru in a pic of the 2 different piston/rod assemblies that I have.
100_4450 (Medium).JPG 100_4451 (Medium).JPG 100_4452 (Medium).JPG 100_4454 (Medium).JPG
  • olcowhand, Trav1s and Cat385B have said thanks
#17 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted February 21, 2016 - 12:34 AM
 The pulling ring is finished for the timing gear on the crank. Just need to locate some grade 8 bolts.
  • olcowhand and Alc have said thanks
#18 toppop52 OFFLINE
toppop52
  • 5,455 Thanks
  • 4,863 posts
Posted February 21, 2016 - 10:22 AM
I agree that asking Boomer is the way to go, the man is an Onan genius.
  • Cjet69 said thank you
#19 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted February 21, 2016 - 01:06 PM
I have contacted him and he has already helped answer some questions. Great guy.
  • toppop52 said thank you
#20 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted February 22, 2016 - 10:03 PM
Got some bolts and removed the timing gear. Shot a vid of the gear removal. When the gear popped loose we thought one of the bolts had snapped, but it was just the gear breaking free.
https://www.youtube....h?v=rNyryuXWD18
Edited by Cjet69, February 22, 2016 - 10:04 PM.
#21 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted March 08, 2016 - 01:14 PM
I installed the P220 I have to get it up and running while the P218 gets rebuilt. Spent some time loosening up a few parts and everything seems to work on it now. I have started a list of items that will need to be rebuilt or replaced like the front end and hydro damper/absorber.  After getting it put together it was pic time and then give it its first job pulling our large burn barrel.
100_4607 (Medium).JPG 100_4608 (Medium).JPG 100_4610 (Medium).JPG 100_4611 (Medium).JPG 100_4634 (Medium).JPG 100_4635 (Medium).JPG 100_4637 (Medium).JPG 100_4633 (Medium).JPG
  • Alc, KennyP and Trav1s have said thanks
#22 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted March 08, 2016 - 03:44 PM
Great to see another save, you'll love it with either engine!
#23 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted March 08, 2016 - 06:56 PM
I just missed another 318 that my niece told me about. It had a blown engine also and he was asking $300 for it. :(
#24 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted March 09, 2016 - 09:22 PM
The only part missing on this tractor that I have found so far is the Headlight harness. Ordered one on ebay and it was delivered today. Now I need to look into some LED bulbs.
#25 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted March 10, 2016 - 09:20 PM
I plugged in the used headlight harness and got nothing. Got the volt meter out and checked at the plug, no power. Checked the switch terminals, still nothing. Went to the switch plug and found power. When I pulled the plug off of the switch I could see the problem. Nothing but rust so a quick run thru the bead blaster and some dielectric got things working. How often can you buy a used harness and all of the bulbs are good? smiley-confused013.gif Now I need to clean the lens.
100_4663 (Medium).JPG 100_4664 (Medium).JPG 100_4666 (Medium).JPG 100_4667 (Medium).JPG
  • olcowhand, Alc, KennyP and 1 other said thanks
Also tagged with one or more of these keywords: john deere, 318
