Mounting Snowblower to the ST/10
5 replies to this topic
#1 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 16, 2016 - 09:17 AM
I know most of you have completed all of your winter projects and have moved on to dreaming of spring. Let's just say I am a little behind.
I picked this 32" blower up about a year ago and have never mounted it. It is actually for a Sears Custom tractor; which shares the same architecture as the ST/10. Should be a fairly easy install.
First thing was to remove the snow plow. A few bolts and the machine is naked:
Sizing it up:
Well that went well and within about twenty minutes, the blower was attached to the machine. Including the shoot adjuster and rear support rods. This should make it work faster:
Then came the fun part; removing the original pulley. Even though I believe this machine has spent almost its entire life inside, Forty+ years have tried to permanently weld the pulley to the crank. Used the medium size puller (couldn't find the large one, its around here somewhere)
It didn't fight the whole way; you know a 1/8 turn and smack with a hammer; sometimes I could turn the puller a 1/4 turn. LOL. Long story short, about 2 hours later, the arms are tired, and the pulley is laying on the floor.
Picture of the crank and the penetration of oil/ATF mixture. Not to bad; minimal rust and the mixture penetrated almost the entire surface.
Cleaned up the shaft and added the snow blower pulley; with anti-seize:
Looked at the spark plug. It's been awhile since this has been changed:
More to come. The fun has just begun.
  • MH81 and Traill95 have said thanks
#2 MH81 OFFLINE
Posted February 16, 2016 - 09:26 AM
Really sweet that you got the pulley with!
Do you have snow to play with?
  • Bmerf said thank you
#3 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 16, 2016 - 10:01 AM
Next up a pulley cover. I have tried for ~1 year to find one. Even ran an ad here: http://gardentractor...r-pulley-cover/
No luck, time to try out some new skills.
Wbakunis was kind enough to supply the dimensions.
Needed to locate some metal:
First a plan:
Time to cut:
Will this work?
Homemade shop round dolly:
A little help from a rubber mallet and this may actually work.
Next was the plate that mounts to the tractor. This will never work:
A little more dolly work and:
Mocked up:
Both sides all welded up and installed; not quite factory but should serve the purpose:
That brings us up to date. Still needs a lot of grinding. Also fabricate the belt retainer and belt engagement rod holder. Will need some body filler at paint time. I have never done anything like this before. It has been a rewarding challenge. I love to fabricate, (not very good or fast at it, but I love it.) Spent about 8 hours to get to this point. 3 hours fabricating and 5+ hours thinking about the next step. I may even finish this in time to actually use it this year.
Thanks for looking,
Brian
Edited by Bmerf, February 16, 2016 - 10:19 AM.
  • Jazz said thank you
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 16, 2016 - 10:15 AM
Unfortunately I didn't. Actually found and bought it off E-Bay a year before I found the blower. I guess I was thinking ahead knowing there would be the opportunity to find a blower later.
We have a couple of inches on the ground, but want to finish up the belt guard and have the blower complete before I use it; just to check for any problems. Paint will come later.
No play time today. Maybe tomorrow. Momma says I've been spending too much time in the dog house (barn) with the girls (tractors).
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 17, 2016 - 07:11 PM
Got a little more done today on the pulley cover. Made and installed the belt retainer. Still lots of grinding to be completed.
Took the ST/10 out for a test drive. The results were less than dismal. Very disappointed. To be honest, I can't blame it all on the Sears. The Ford with the Haban blower didn't do much better. Several things were working against me. The weather was beautiful for the middle of February. Sun was out, the snow was melting, 33*. Wet heavy snow. Not ideal snow blowing weather. Shoot kept clogging. The new belt was way to loose; I didn't think the Kevlar belts stretched? The impellers inside the blower housing seem to have excessive clearance. About 1/2" between the housing and the impeller.
Has anyone tried adding a rubber extension to the impeller? I watched a YouTube video and it seems to make a world of difference. Will try this if another new belt doesn't help.
Thanks For looking.
Brian
Oh yeah, the failure shot:
One of the Ford's effort:
#6 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,662 Thanks
  • 2,852 posts
Posted February 17, 2016 - 07:36 PM
Nice job on making the shields - they look great.
  My experience with a snow caster is that you have to feed the snow into them very quickly to get them to blow the snow very far.  If the snow is wet, which at 33 degrees it probably was, they will plug very easily and often.  A nice smooth painted surface (waxed if possible) does help some to keep the snow from sticking.  I have heard of people spraying the inside of the chute with pam or Fluid Film which is supposed to help.
