Possible 1886 and loader purchase.
1886 johnson fel
29 replies to this topic
#16 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 15, 2016 - 08:44 PM
I volunteer to do a 3 year case study on 1886 frame cut outs. I will need at least 5 of them. Contact me for the location of the nearest Fastenal you may ship your 1886 to.............. :D  :wave:
Cat just come get the 1886-04 I have in the back barn. :thumbs:
#17 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted February 15, 2016 - 08:46 PM
Any Ida's on model of that loader?
#18 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 15, 2016 - 08:49 PM
Looks to be a Johnson modal 14 with a small bucket.
  • AA Hayes said thank you
#19 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 15, 2016 - 09:07 PM
Loader looks pretty good on the side showing,I see the belt guard is still on the loader pump,most get miss placed,muffler is not original,I think you have a lot to work with there, hope you can make a deal
#20 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted February 15, 2016 - 09:10 PM
Yeah I noticed the muffler. I will be getting an original. Also going to put an original on my ht20 when I do the rebuild
#21 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted February 16, 2016 - 09:42 AM
Well, I have been really searching for a Bolens iseki or an older kubota with 4x4, I have decided that it is worth the wait to find the loader tractor that will better suit my needs.
  • Bolens800uk said thank you
#22 Cvans ONLINE
  • 9624 Thanks
  • 7318 posts
Posted February 16, 2016 - 11:25 AM
What is the load rating on the Johnson loader?
I have my relief valve set to lift around 400lbs. That's when the rear of my tractor starts getting light. So far the loader has held up very well.
#23 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted February 16, 2016 - 12:42 PM
Like Wilburj says keep moving when turning with a load, just like using an old car without power steering. Also that big cast iron axle support in the front is what you want to be careful about. It can crack  if you run into holes with the front tires or do anything that wants to twist the frame rails. That casting is bolted onto the frame rails on both sides with two bolts. Check all around that area to be sure that casting is not cracked. You will need to look inside under the front where the pto belts and pulleys are. With a flashlight you can peer in there and just see the inside of the frame rails where that casting bolts on. They typically break along where it is bolted in sometimes you will see the pto pulleys sort of free floating if it is cracked. Here are some pictures of mine when it broke on my HT23.
  • LPBolens, blackjackjakexxix, Cvans and 2 others have said thanks
#24 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted February 16, 2016 - 12:48 PM
There's one thing in the UK....:)
#25 Cvans ONLINE
  • 9624 Thanks
  • 7318 posts
Posted February 16, 2016 - 01:37 PM
Great reply Husky!  :thumbs:
#26 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 16, 2016 - 02:38 PM
There nice an all but I rather have a machine built by Americans. I have a iseki h1502 my dad bought new in 88 but didn't get 4x4 an now I have a j.d 670 with 4x4 loader an 60in belly mower I inherited an it's ok but I still love my Bolens
  • OldBuzzard, LPBolens, blackjackjakexxix and 1 other said thanks
#27 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted February 16, 2016 - 05:33 PM
I do love my Bolens and will always have a LF or a couple of them, but, I feel for the rugged terrain on my property and heavy work I would do with it, a larger tractor might be more suitable. Also, his price is a bit higher than I think it is worth. It is was price where I think it should be it would be here already.
#28 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 16, 2016 - 05:44 PM
I would agree when I seen it the price is high.
#29 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 16, 2016 - 06:30 PM
Uh, you do know don't you, that the JD 670 is built by Yanmar, and Deere jus puts their name on it?
#30 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 16, 2016 - 07:10 PM
I kno that Dave but thanks for the heads up
Also tagged with one or more of these keywords: 1886, johnson fel
