Briggs and Stratton Off a Montgomery Wards Squire 14
7 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted February 15, 2016 - 12:08 PM
I can't get the starter pulley off I removed the two bolt on the screen but it won't come off.
  • 14,730 Thanks
  • 15,470 posts
Posted February 15, 2016 - 01:16 PM
Can you post a picture so we can see what you have there?
  • boyscout862 and Tecumseh power have said thanks
#3 bbuckler OFFLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted February 15, 2016 - 02:26 PM
#4 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,111 Thanks
  • 4,883 posts
Posted February 15, 2016 - 02:41 PM
I believe thats the end of the crankshaft sticking out the middle.  You need to sand all the rust off that you can possibly get and then soak it in penetrating oil.  They can be stuck bad.  When you go back together put some Anti-Sieze on the crank so it never rusts on there again.
If you have a puller that should help but go easy.
DO NOT pry on the fan/pulley!   That is pot metal and will break instantly.
Good Luck!!
  • boyscout862 and bbuckler have said thanks
#5 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted February 15, 2016 - 03:24 PM
I had similar experience on my simplicity 700 briggs. It wouldn't budge. spray it with pb blaster and try again next week. that's what I did and a week later it popped right off.
the correct briggs puller is a must too
Edited by jabelman, February 15, 2016 - 03:25 PM.
#6 bbuckler OFFLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted February 15, 2016 - 03:28 PM
Good Luck!!
if it broke I would be ok with that has long as the crankshaft didn't break. I putting another one on with out the driveshaft adapter.
#7 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted February 15, 2016 - 03:53 PM
I agree with Gtractor. Soak it with penetrating oil and grab the flange with a big pair of channel lock pliers and try rotating the adapter to try to get it to free up. Don't grab the small nub sticking out. Here is a pic of the assembly for any help and the bolt sizes may not be the same as yours, it is from a different model. Hope this helps.
Tim
Edit......   Wow, you guys are fast today.
Edited by PGHsteelworker, February 15, 2016 - 03:56 PM.
  • bbuckler said thank you
#8 EricFromPa ONLINE
EricFromPa
  • 3,513 Thanks
  • 3,064 posts
Posted February 15, 2016 - 03:56 PM
Tap on it with a small hammer then turn it.The drive coupler isn't on the crank very far.It's on there Maybe 3/4".There is no woodrif key on either part.So turning it back and forth will loosen it up.Take the belt off before trying to remove the booster fan if you can.
That's the same coupler that is on my 2 Gilson Hydro 16s and Montgomery Wards 16 twin.That stub sticking out isn't the crankshaft.
Edited by EricFromPa, February 15, 2016 - 04:00 PM.
  • Gtractor, boyscout862 and bbuckler have said thanks
