HF Compact Bender mounting ?
28 replies to this topic
#16 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 16, 2016 - 11:32 AM
Looks like the best spot is in between the doors.
Unless I forget and leave the handle out ,,,, either side I'm doomed , wife's Blazer is on one side and her Malibu is in the other lol
#17 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 18, 2016 - 06:48 AM
Borrowed a hammer drill yesterday , never used one before , can't believe how quick it was to drill the holes !!  I've only ever used my old 1/2" drill with those masonry bits , heck even in just concrete blocks it was a pita .  I ended up putting holes at each end of the garage and turned the ones between the garage doors at a angle . From what I've been reading you pull the handle mostly clockwise so this way I would be able to keep the door closed if I ever had to extend the handle all the way starting form the right side . I  used 2 part epoxy  & from what the instruction said about curing time & as cold as the garage is it will be 72 hours to cure so I'll be able to try this bender out by the weekend
  • MH81, KennyP and MFDAC have said thanks
#18 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted February 18, 2016 - 07:00 AM
Glad you got it mounted. Let us know how it works! :camera: Please!
#19 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 18, 2016 - 08:55 AM
Here's the manual for the HF bender and some info on the better Hossfeld ones, found another one but for some reason it wouldn't load , maybe to big of a file ?
Attached File  38470.pdf   1.12MB   116 downloadsAttached File  Hossfeld_Bender_Model1_Catalog.pdf   1.05MB   78 downloadsAttached File  Hossfeld_Bender_Tooling_Brochure.pdf   1.91MB   97 downloads
  • Bruce Dorsi and KennyP have said thanks
#20 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 21, 2016 - 07:28 PM
Sometimes it doesn't pay to "over think" yep left plenty of room on the right side for the handle but never thought about how long of a piece of stock would fit before hitting the door :wallbanging:  DSCN2008.JPG   DSCN2006.JPG
This is my first try at bending it 1 1/4" x 1/4" steel . it bent pretty easily . DSCN2010.JPG
Now I'm going to try to scrounge up things for bending dies for things like tubing and eye bolts .
#21 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted February 21, 2016 - 07:40 PM
Oops! Gonna have to open the door for long stuff!
#22 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted February 25, 2016 - 07:17 AM
I'm thinking about getting one of these, Al. Just not sure where I could mount it, a little short on concrete floor space at the moment.
#23 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted February 25, 2016 - 08:39 AM
Kenny that's the same with me , I  put those concrete anchor near my work bench too just going to use some allen screws to keep the dirt out floor flush . Now thinking more about having those there I'm going to make a base to match the bolt pattern so I can use my HF mini tire changer on .  Maybe I should make a mounting system with a 2" receiver tube  then I could use it for tire changer ,bench grinder ( now mounted to a piece of plywood then gets clamped to the work bench )  and a wire wheel on wood too .Just would need  2" OD  to slip inside  .Still moveable with just 4 bolts then the floors clean again .
#24 Jazz OFFLINE
Jazz
  • 2,394 Thanks
  • 1,443 posts
Posted February 28, 2016 - 01:51 PM
Its one of those things that could be anchored in the ground outside.  Paint it and hang a flower pot on it just like the manual tire changer for as often as they might get used.
#25 toppop52 OFFLINE
toppop52
  • 5,272 Thanks
  • 4,768 posts
Posted February 28, 2016 - 05:46 PM
I'm going to mount mine either in the garage between bays, all I have do is back out vehicles if they're in there. Or in my tractor shed and just move one tractor to use it. I'm not going for dedicated space.
#26 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted March 01, 2016 - 07:17 AM
I had a 20% off coupon, so I picked one of these up yesterday! Haven't unpacked it as yet. Maybe this weekend! :dancingbanana:
#27 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted March 01, 2016 - 08:48 AM
Good deal Kenny :thumbs:  I'm sure you will use it more then me so I'm hoping to pick up some tips from you
#28 KennyP OFFLINE
  • 38,419 Thanks
  • 45,945 posts
Posted March 01, 2016 - 09:03 AM
Gotta figure out where it will be mounted first. I'll open the package and look at the room that is needed for it. I may have to do the anchors similar to yours so I can set it up to use and store elsewhere when not needed.
#29 toppop52 OFFLINE
toppop52
  • 5,272 Thanks
  • 4,768 posts
Posted March 01, 2016 - 09:27 PM
I think I'm going to buy one as well, along with a tire changer. Both are indispensable when you need them.
  • limebuzz and Alc have said thanks
