Building a diesel puller.
13 replies to this topic
#1 metcalf OFFLINE
metcalf
  • 2 Thanks
  • 4 posts
Posted February 14, 2016 - 11:59 AM
I'm in the process of gathering all the parts for a diesel puller build. My question is what is the best way to go for a motor. Yanmar or kubota? I'm not planning on getting real stupid on modifying. Well not for now.
  • Chris11 and Dieselcubmike have said thanks
#2 HDWildBill OFFLINE
  • 8,978 Thanks
Posted February 14, 2016 - 12:08 PM
Welcome to GTTalk.  I'm not a diesel guy but we do have several member who are and they should be along before long to give you some advice.
  • Chris11 said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 14, 2016 - 01:04 PM
It seems like there are more Kubotas out there to be had. Yanmars are less common in industrial applications except for marine use where they are used extensively. It may come down to what you can find at a price you can afford.
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 14, 2016 - 05:41 PM
Hello there and welcome. There are many questions to be had. If you plan on ever running modifications there is no real aftermarket for any diesel performance keep that in mind. First of if you plan on pulling locally find out if your able to run a diesel and what rules your allowed. Next off grab yourself a set of the LPSD national rules. I run a Kubota simply because in my experience they are a very strong engine to begin with. However just like any other diesel if you have to rebuild it will become pricey. Theres a diesel garden tractor pulling page on facebook with a lot of helpful information.
#5 olcowhand ONLINE
  • 42,421 Thanks
  • 31,810 posts
Posted February 14, 2016 - 09:02 PM
I have both Yanmar & Kubota diesels, but I lean towards Kubota.
#6 Cvans ONLINE
  • 7,089 Thanks
  • 6,297 posts
Posted February 15, 2016 - 12:00 AM
I have both Yanmar & Kubota diesels, but I lean towards Yanmar.  :smilewink:
I just had to do it Daniel.
They are both excellent engines. As far as the older ones go it has been my experience that the older Yanmar diesels are easier starting if both are in good condition. The older Kubota engines need to use glow plugs for a fast cold starts.
This is just they way it has worked for me.
Edited by Cvans, February 15, 2016 - 12:01 AM.
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,292 posts
Posted February 15, 2016 - 04:01 AM
:welcometogttalk:
#8 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted February 15, 2016 - 07:30 PM
welcome, Everyone on here is very helpful. Don't be afraid to ask questions. Good luck with your project.
#9 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted February 15, 2016 - 08:22 PM
Welcome..... lots of great help on here it can really save you some trial and error.  I have been using yanmar and kubota for over 30 yrs in the golf industry. The are both good engines but I like the kubota. I have seen some of them run up to 6500 hrs just a great engine. Good luck on your project..
#10 metcalf OFFLINE
metcalf
  • 2 Thanks
  • 4 posts
Posted May 15, 2016 - 09:00 AM
Well i finally found a kubota motor close to home. I'm committed now. Probably not get any building done this summer. But I'm on the hunt for parts that willl be needed. I probably wil get the pump and injectors started. Anyone have any recomendations for  these of who to talk to?
#11 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted May 15, 2016 - 06:00 PM
glad you found one what model is it? The pump and injectors are a very costly item I would save your money for the more important items like clutch setup or diff modifications. What tractor are you planning to put it in?
#12 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 15, 2016 - 07:31 PM
As dave mentioned, yes having the pump and injectors done is very costly. You will need a good clutch and a very heavy duty rear end. Need a good turbo as well. I have 2500$ In just the rear end. Youll need it for all the torque these little things make. And for a clutch you can use a 5 puck setup and go from there. I just upgraded to a double disc from Zack kerber and I love it. My best advice would be just get your feet wet and go from there. I see quite a bit of people throw money at these things and not know how they are. Theyre a caged animal ready to be let loose.
#13 metcalf OFFLINE
metcalf
  • 2 Thanks
  • 4 posts
Posted May 16, 2016 - 08:52 PM
Motor is a d1105. The frame will be from a 149 I have or just go and make a new one. I might be time and labor ahead by making my own frame.  Already planned on getting the clutch from kerber along with the flywheel. My biggest hang up is getting planetary or not. That has to be decided before I can do much work.  I know longevity wise the planetary setup is probably the best option.
#14 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 16, 2016 - 11:12 PM
The way I see it is if you already have plenty of work done and you have a healthy drive line then maybe. From what I heard Kerber doesnt have anymore planetaries in stock. Not sure on if hes updated it or not. Theres a group on facebook under Diesel garden tractor pulling you can check out for more info.
