Wanted narrow rims for 5.00-12 tires
11 replies to this topic
#1 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted February 11, 2016 - 04:28 PM
I bought a pair of old Firestone 5.00-12 tires and was going to put them on a standard 5-lug EWC 12x5 rim and they are just too wide for the tire.
The tires are old and weathered but they are still holding together for now. I have too much into them for being old used tires and was hoping I could find a narrower rim so I could still use them.
Would anyone here a pair of something narrower they would be willing to part with?
  • Oldford said thank you
#2 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted February 11, 2016 - 08:41 PM
I may be able too help. My wagner has some pretty narrow rims on it. Can they be masured with tirs on the rims to know how wide you are looking for?
Mike
  • RAJ said thank you
#3 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted February 11, 2016 - 08:51 PM
Thanks Mike. Mine are 5" between the bead. If you can measure through one of the holes in the rim
#4 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted February 11, 2016 - 08:56 PM
...to the first step. You'll have to somewhat guess but I'm guessing the next size down would be about 3 3/4" at the bead. Even if you can measure the outside to outside we could still compare it that way. Mine are 6" total width.
#5 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted February 11, 2016 - 08:57 PM
#6 MiCarl ONLINE
MiCarl
  • 1,913 Thanks
  • 1,020 posts
Posted February 11, 2016 - 09:54 PM
If your rims have a tire on them the tire size should give you an idea the rim width.  In other words, if the tire is 5.00 or close to it it's probably the rim he needs.
#7 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted February 12, 2016 - 01:37 AM
Here's a picture of mine. They are definately narrow. I'll measure when I get home today
Mike
  • RAJ, Alc and Tbrooks have said thanks
#8 MiCarl ONLINE
MiCarl
  • 1,913 Thanks
  • 1,020 posts
Posted February 12, 2016 - 07:25 AM
I'm guessing you're looking for used wheels.  If new is an option I suspect THIS is what you're looking for.
#9 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 393 Thanks
  • 118 posts
Posted February 12, 2016 - 09:43 AM
Generally the correct rim size measured inside to inside of the rim flanges will be about one inch less then the tire width.  As an example an 8-24 tire would use a seven inch wide rim.  A 7-24 tire would use a six inch wide rim.
Cliff
#10 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted February 12, 2016 - 10:02 AM
I assumed a 12x4 rim would be the correct size for a 5.00-12, not sure if there was anything narrower. Thanks for the link to Miller. Those are right, just out of my reach.
#11 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 13, 2016 - 09:59 AM
I'd have to check my inventory but I might have a pair of 4" wide rims.I just need to make sure I have enough for the tractors I have.
#12 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted February 13, 2016 - 01:29 PM
I checked on mine today and they appear to be 3-4" wide with 5-12 tires mounted on them. I think w found a match. PM me.
Mike
