Best Belts Available?
20 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted February 12, 2016 - 10:31 AM
No, that's not quite my problem. When a quality belt is new it doesn't quite want to fully release, it drags. Once it softens up, it's fine. If an owner buys the WH brand belts, which are more pricey, they don't have this problem.
#17 Bolens 1000 ONLINE
  • 14,978 Thanks
  • 18,136 posts
Posted February 12, 2016 - 10:32 AM
Thats a material issue or size issue then.
#18 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted February 12, 2016 - 10:33 AM
How long do the WH belt usually last
#19 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted February 12, 2016 - 10:42 AM
I'll cast another vote for Kevlar belts as I can't recall ever having to replace one. More money up front but well worth it in the long haul.
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted February 12, 2016 - 10:50 AM
I have a Ag grade belt from Farm & Fleet on my WH. It's been on there for 3-4 years.
If you are replacing belts frequently, you should check for size errors or alignment issues.
FYI On a WH, the belt guard is absolutely essential for correct belt alignment.
Edited by LilysDad, February 12, 2016 - 10:55 AM.
  • MolonLabe said thank you
#21 adamjd200 OFFLINE
adamjd200
  • 2,045 Thanks
  • 2,173 posts
Posted February 12, 2016 - 01:46 PM
Generally use the blue ones from TSC, with one exception, I get any JD drive belts directly from the dealer.
