Could use a little help with setting up the engine mounting platform for my T75. I had taken it apart during the summer and am finally getting round to finishing it up. The engine is out being Refreshed, and I forget how the rubber isolators go. The originals were very loose and the three of them were all different and used all manners of attachment so I assume they were not correct as I got it. I have it set so the rubber isolators metal part is at the bottom of the cast iron panel........so the panel sets on top of the metal grommet flange. I figure the larger end of the grommet goes toward the bottom, and the domed washers go onto the top of the isolators b4 bolting everything down. Sound right?? I am going to trim the excess bolt length of the 8/32 screws, and replace the original bolts with new grade 5 or 8 (Availability dependent) as the originals were rusted and broken. There was also a domed metal washer on the mount that goes onto the pipe frame??? maybe it is needed or maybe someone just tossed it in there. Any help appreciated!!! Hers a picture of it b4 cleaning up!!
Help with T75 tractor engine mounting platform (rubber grommets)
#1
OFFLINE
Posted February 10, 2016 - 06:53 PM
#2
OFFLINE
Posted February 10, 2016 - 07:35 PM
Sounds like you've about got it right to me. Yes - the fatter side of the rubber shock mount should face DOWN. On those cup washers - you'll notice that three of those have a deeper cup shape than the other three. The deeper ones will go on the bottom side and shallow ones will be on top. So, all mounts should have a washer on both top and bottom - even the one that rests on the tube frame.And you're right about the metal flange being mounted on the bottom side of the engine mounting plate.
- Clint and Doxey have said thanks
#3
OFFLINE
#4
OFFLINE
Posted February 10, 2016 - 09:02 PM
#5
OFFLINE
Posted February 10, 2016 - 09:28 PM
Enjoyed all the Panzer pics. A little off topic, but does anyone know the diameter of the rubber reverse drive wheel. I think that's what you call it. I'm going to try and make one, mine is out of round. For above Panzer.
5" by 1" thick. McMaster Carr has the material
- Doxey said thank you
#6
OFFLINE
Posted February 10, 2016 - 10:24 PM
Thanks for the info, I think I have 3 deeper washers and 1 shallower one. I will clean them up in the blast cabinet and take pic's to make sure. If that is what I have..........and I am pretty sure it is, I will need 2 more of the shallow ones (tops) anybody know where they can be had???? Thanks !
#7
OFFLINE
Posted February 11, 2016 - 11:00 AM
Edited by jdcrawler, February 13, 2016 - 02:20 PM.
#8
OFFLINE
Posted February 11, 2016 - 01:24 PM
Edited by karl, February 11, 2016 - 01:25 PM.
#9
OFFLINE
Posted February 11, 2016 - 07:45 PM
That's a good question. Now that Dandy Sales has closed shop, I'm not sure where you could get them unless somebody on here pops up and has a bunch of extras taking up space in a coffee can. You could get by with flat fender washers for the time being.
#10
OFFLINE
Posted February 12, 2016 - 06:44 AM
Single stud shock absorber washers are mighty close.
