Cub 582 started earlier, but won't now
1 reply to this topic
#1 daytime dave ONLINE
  • 4,986 Thanks
  • 6,611 posts
Posted April 27, 2011 - 05:45 PM
I was at dad's today, to get his back up generator going as his newer emergency generator was down for repairs. It started right away, so that was easy. He said while I was there, the 582 could use an oil change.
It sat all winter with a trickle charger on the battery. A turn of the key and it only ticked away. I got my jump pack and it fired right up. Drove it around, changed the oil. The starter switch was getting bad, as the key just would go around and then not go back in. A few more starts with the jump pack and the starter switch was a goner.
I called Napa and they said they had a couple. I'm not too mechanically inclined, so I brought the old one. The fellow said either starter in stock would work, they were both five prong. Installed it and nothing. Not even a ticking. Went back and got a new solenoid and installed that. Nothing. Not even ticking with the jump pack. The voltage gauge moved slightly each time I tried the switch. I checked all connections, I wire brushed the connections I could. I tried another battery that had also charged all winter. Same thing, nothing. Ground was cleaned and checked. Dad and I are now wondering if anyone can offer any suggestions.
Thanks.
Edited by daytime dave, April 27, 2011 - 05:51 PM.
#2 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted April 27, 2011 - 06:16 PM
Take your multimeter, and make sure you have good continuity
Switch body to negative cable
12v at the switch
