Tecumseh Engine Differences?
5 replies to this topic
#1 CraftsmanGT OFFLINE
CraftsmanGT
  • 195 Thanks
  • 234 posts
Posted February 10, 2016 - 01:08 PM
Hi everyone, I'm wondering what the difference between a Tecumseh H70 and HM70 is? I'm working on repowering my neighbors snowblower for him which has an H70 with an HM70. I noticed physically they look the same just the governor setup is a bit different and the intake and exhaust are switched around between the two. This H70 is an aluminum bore and the HM has an iron sleeve, and generally I thought all H series were aluminum bores but I've found some with sleeves. If someone could help clear this up that'd be great. I don't see many Tecumseh's anymore and I'm just learning about the model designations. Thanks
#2 dodge trucker ONLINE
dodge trucker
  • 1,523 Thanks
  • 1,977 posts
Posted February 10, 2016 - 06:20 PM
HM is actually a different engine family, it is a wider block, head is different,  and yes all HM had cast iron sleeves where the H series didn't.  As long as your crank matches up length and diameter wise and is the same height from the mounting surface they should swap out fine.
#3 EricFromPa OFFLINE
EricFromPa
  • 2,544 Thanks
  • 2,475 posts
Posted February 10, 2016 - 08:05 PM
Alot of Tecumseh parts are interchangeable throughout there whole engine line.I used a Carb off of a 4hp push mower on a H50 for a while till I found the correct one that was usable.Also used a few governor parts,flywheel,blower housing,coils and recoil starters off of a HM on an H.
I'm not certain but I've heard an HM isn't rated for Side load on the crank because it has thinner bearing bosses and thinner case material.
  • limebuzz said thank you
#4 Tecumseh power ONLINE
Tecumseh power
  • 1,124 Thanks
  • 891 posts
Posted February 10, 2016 - 08:15 PM
Hm is the "medium frame" block. That is why it looks different in size than the H.
#5 dodge trucker ONLINE
dodge trucker
  • 1,523 Thanks
  • 1,977 posts
Posted February 10, 2016 - 08:47 PM
They made versions of this engine a few different ways, that you can't tell from just looking at one. Some had the PTO side crànk bearing as just a machined hole in the cover while other versions of the same engine had bronze bushings here while others had a ball bearing there, those would be the "XL" versions.
#6 drbish ONLINE
drbish
    Collecter
  • 1,278 Thanks
  • 1,209 posts
Posted February 11, 2016 - 04:18 PM
Here are the Engine specs for the H70 and the HH70 This came out of the Tecumseh engine specifications book
dated 8/81.The book is 81 pages and will attempt to put in the Manual section
Attached File  tec7.pdf   1.68MB   40 downloads
