Ferguson TO 30 Issues
31 replies to this topic
#1 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 09, 2016 - 09:54 PM
So yesterday evening I replaced the exhaust manifold and muffler on the old ferguson. Today I fire it up to plow snow and and all of a sudden it's only running on 3 cylinders! Did I screw something up when replacing the manifold? Ideas as to what could have caused this? Recently replaced the distributor cap, rotor button, points, condenser, plug wires and plugs. Coil was also replaced some time ago. Tractor has been converted to 12 volt.
#2 MH81 OFFLINE
Posted February 09, 2016 - 10:08 PM
Did you use original bolts?
Other than that, I would change plugs, then check compression.
#3 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 09, 2016 - 10:18 PM
I used original bolts on everything except the muffler clamps. Plan on picking up new plugs tomorrow.
#4 MH81 OFFLINE
Posted February 09, 2016 - 10:22 PM
Do you have a spark tester?
#5 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 09, 2016 - 10:24 PM
I don't actually. I think that is something I need to get.
#6 MH81 OFFLINE
Posted February 09, 2016 - 10:26 PM
Yeah, for less than $10, you're able to answer many nagging questions.
Except the meaning of life... That one is either Garden Tractors or Family... Not sure yet.
  • boyscout862, TomLGT195 and GTpicker01 have said thanks
#7 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted February 09, 2016 - 10:38 PM
Don't you hate it when you fix one thing, then another demon comes along!
  • MH81 and GTpicker01 have said thanks
#8 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 09, 2016 - 11:09 PM
The more tractors I accumulate the more often that seems to happen lol
  • Alc, jpackard56 and boyscout862 have said thanks
#9 ducky ONLINE
  • 1,989 Thanks
  • 4,108 posts
Posted February 09, 2016 - 11:26 PM
If all you did was replace the intake gasket look for an intake air leak at the cylinder that is not firing.
I assume all was well before.
  • MH81, boyscout862 and GTpicker01 have said thanks
#10 propane1 ONLINE
propane1
  • 9,145 Thanks
  • 4,281 posts
Posted February 10, 2016 - 04:56 AM
Plugs. Or you moved a wire , while doing the repair.
Noel
  • GTpicker01 said thank you
#11 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted February 10, 2016 - 08:44 AM
Fouled plug more than likely
#12 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 10, 2016 - 08:55 AM
I'm hoping! As soon as I get home today I'm changing plugs!
  • propane1 said thank you
#13 MH81 OFFLINE
Posted February 10, 2016 - 10:27 AM
Didn't think about the intake being in there too.
I still think plugs, but it'd be worth it to spray a little carb cleaner or starting fluid along the intake gasket to ck for air.
Just watch, this new stuff will peel paint.
#14 olcowhand ONLINE
  • 42,432 Thanks
  • 31,812 posts
Posted February 10, 2016 - 10:34 AM
I think WD40 will alter firing too without the chance of paint peel.
  • MH81, TomLGT195 and propane1 have said thanks
#15 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 742 Thanks
  • 615 posts
Posted February 10, 2016 - 05:05 PM
Changed plugs and that didn't work. Sprayed carb cleaner around the gasket and that didn't alter the firing......I am suspicious that the new manifold may have a casting defect in it not allowing fuel to a cylinder. I got an inline spark tester and I have spark to all 4 cylinders. Next I am going to check compression just to make sure it's not a valve or head gasket problem. Any idea how many psi of compression I should be getting out of that engine?
