* * * * * 2 votes
Time to refresh the Bolens 1000
143 replies to this topic
#46 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 29, 2016 - 05:33 PM
I got the pto assembly back on,a couple decals on,the knobs on,the mower deck bracket on,and got the tower in primer,got it back down on some junk wheels so I can move it around,tomorrow going to get the tower painted,I'm trying something with the steering wheel,it is worn down to the black in places,I bought some paint today that is supposed to work on plastics,will see,if it doesn't work I will have a mess to clean(lol),here's a couple more pics
  • Bolens 1000, LPBolens, Bruce Dorsi and 6 others have said thanks
#47 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted February 29, 2016 - 06:04 PM
If I concentrate on the frame, it looks great. But, man 'o live are those rims dragging that thing down.....   :rolling:
Good luck with the steering wheel!
  • Bolens 1000 and blackjackjakexxix have said thanks
#48 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted February 29, 2016 - 06:13 PM
It looks even nicer outside  in the sunlight - sure does make the paint look nice.  When I redid my first 1050 I wondered if it had metallic in the paint but it was so weather beaten I could not tell and as a result I just went with a close brown colour in acrylic enamel .  If I ever repaint it again I will probably go with the metallic.
#49 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted February 29, 2016 - 06:16 PM
I'm in the same boat as you, I think we're going to have to see when the metallic ended if it did at all, I'm almost betting it was used the whole run and we never noticed. I think we were all suckered into the ''Leather brown" so many posted on the web as a match years ago on the old groups.
  • blackjackjakexxix and 29 Chev have said thanks
#50 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted February 29, 2016 - 06:34 PM
I am not sure if all the later 1050's had the metallic but I now believe the early ones did.  The first 1050 has the white steering wheel and after seeing the paint on Rick's 1000 I am convinced it had the metallic which blended in so well as a "rusty look" that I could not tell.  The second 1050 has the black steering wheel, the hood and transmission cover had the newer style decals and the hood does not have the cut out for the exhaust (may not be the original hood) and I did not see any evidence of metallic in the brown paint on it - it did not have the same "rusty look".  I believe both tractors were the 192-02 model as I could just make out the 02 on the stickers but the serial numbers were beyond readability.  I have attached pictures of the area around and under the serial number from the 1050 with the black steering wheel - unfortunately I did not have a digital camera when I redid the first 1050 so I do not have any before pictures from it.
Edited by 29 Chev, February 29, 2016 - 06:46 PM.
#51 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 29, 2016 - 06:41 PM
Rims are on the list,maybe over the weekend
  • Cat385B and 29 Chev have said thanks
#52 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 29, 2016 - 06:48 PM
Brian, I need to say Thanks again for the lift handle grip,glad you had them, really makes the difference,and also special Thanks to WrenchinOnIt for doing the repair work on the tower,it had a couple small cracks around a couple bolt holes
  • Bolens 1000 said thank you
#53 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted February 29, 2016 - 11:07 PM
Boy that is a sweet color, great job Rick!
#54 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted March 01, 2016 - 12:21 PM
Ok, got the steering wheel done,the color is a little off but was limited to colors with this type paint,there was some black showing through and I took a gamble on doing this,with the rubber coating most paints don't dry and are sticky to the touch,I sanded this real good with 120 wet dry sand paper,wiped it off with lacquer thinner,let it dry,then applied paint in thin coats,you only have a 4 hr window when appling it, I'm real happy with the results, I used Krylon ColorMaster,Ivory Gloss,(Wal-mart)
  • LPBolens, TomLGT195, Chubien and 2 others have said thanks
#55 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted March 01, 2016 - 01:21 PM
If you want to go all out on a steering wheel, Eastwood sells repair and recoat materials. (No, I don't work for them)
Edited by LPBolens, March 01, 2016 - 09:22 PM.
  • blackjackjakexxix, TomLGT195, Chubien and 1 other said thanks
#56 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted March 01, 2016 - 07:31 PM
Got the dash tower done today,also got the choke and throttle cable covers painted,hope to get started on the engine repaint tomorrow
Edited by blackjackjakexxix, March 01, 2016 - 07:33 PM.
  • Bolens 1000, LPBolens and 29 Chev have said thanks
#57 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 01, 2016 - 07:36 PM
The Throttle assemblies were not painted at the factory, they were white originally
  I had some pretty bad ones I soaked in bleach and scrubbed they look almost new.
  • LPBolens, blackjackjakexxix and TomLGT195 have said thanks
#58 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted March 01, 2016 - 08:22 PM
Man that does look great but I thought I had my 850 perfect but now you guys say it's supposed to be metallic man I dont want to do it all overimage.jpeg
Edited by 1967bolens collector, March 01, 2016 - 08:25 PM.
  • LPBolens, blackjackjakexxix and Austen have said thanks
#59 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted March 01, 2016 - 08:26 PM
I don't know why the pic are upside down
#60 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 01, 2016 - 09:00 PM
The brow pain looks great. :thumbs:  :thumbs: :thumbs:
It just sits there and glows.
