Snowblower skid adjustment for gravel, pavement
13 replies to this topic
#1 jrfiero OFFLINE
jrfiero
  • 2 Thanks
  • 1 posts
Posted February 08, 2016 - 05:05 PM
My 42" snowblower works pretty well, but I have the skids all the way down so I won't throw too much gravel into the woods, lawn, elsewhere.
But when I get to the paved, unplowed road it leaves too much snow, which doesn't melt very well.
I've been thinking of some type of adjuster, not the three bolts that hold each skid on, but levers, or slip-on/off risers so I can switch back and forth gloved and without tools.
Anyone have something similar, or have thoughts?
Thanks,
Jonas
Craftsman G5500
42" Snowblower, belt drive, manual lift
wheel weights
chains on all four wheels (fronts help it steer)
milk crate bolted to a receiver with chains and flathead Ford exhaust manifolds in it for a little more weight
  • MH81 and boyscout862 have said thanks
#2 MH81 OFFLINE
Posted February 08, 2016 - 05:18 PM
Some of the wheel horse blowers had little roller wheels. I don't think they worked well, but they were on an adjusting arm.
Maybe that would give you an idea.
  • Bmerf said thank you
#3 MH81 OFFLINE
Posted February 08, 2016 - 05:21 PM
Like this
#4 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted February 08, 2016 - 05:31 PM
Just some large wing nuts should work.
  • Tecumseh power said thank you
#5 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted February 08, 2016 - 05:45 PM
What about steeling the wheel height adjusters from a worn out lawn mower? Just move the lever to adjust the height. Use wheels or skids. Good Luck, Rick
  • Gtractor and TomLGT195 have said thanks
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,989 Thanks
  • 10,009 posts
Posted February 08, 2016 - 06:26 PM
Can you post a close up pic of the current set up?
#7 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 08, 2016 - 06:30 PM
Welcome to GTtalk Jonas! Good luck on your input too.
#8 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted February 08, 2016 - 06:57 PM
I have been thinking about this for a while. But I want to do it using hydraulics. I want to use two cylinders attached to two skids/shoes so I can raise and lower the blower for gravel or hard top. I have not figured it all out yet, but some day. I have wondered why some of the commercial snow removal companies don't have this all ready, and maybe they do. Just my thoughts.
Any way, not much help to you.
Noel
Edited by propane1, February 08, 2016 - 07:07 PM.
#9 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted February 09, 2016 - 02:23 AM
Hydraulic lift is a very good idea you have
#10 TAHOE ONLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted February 09, 2016 - 09:33 AM
A lot of guys take a piece of 2" PVC pipe, cut long ways and slip over bottom of the blade for gravel. I hear it works great from pushing too much gravel, but not sure if it would work on cement/pavement.
Maybe make one that slides on/off pretty easy?
Edited by TAHOE, February 09, 2016 - 09:34 AM.
#11 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted February 09, 2016 - 10:33 PM
On large scale snow throwers such as runway type models I have seen hydraulic actuated shoes. Seems like overkill for a driveway but that's the beauty of knowledge tools and unlimited cash flow, overkill becomes simply necessary. Good luck and don't over engineer to much, the future maintenance will give you more headache than the problem you solve.
#12 Greasy6020 ONLINE
Greasy6020
  • 1,479 Thanks
  • 1,402 posts
Posted February 10, 2016 - 09:06 AM
I second this opinion. Makes sense and is easily adjustable...
#13 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted February 10, 2016 - 04:08 PM
Craftsman G5500
Maybe I'm missing something, but why can't you adjust the skids for pavement, and raise the snowblower slightly with the manual lift when working on gravel?
Many manual lifts have several locking positions.  ...If needed, it may be possible to create a new locking position for the lift.
If that is not possible, maybe you can alter the lift linkage which raises the snowblower, by drilling another set of holes to raise the blower slightly.
Where does the "floating" of the attachment occur?
Pics of what you're working with would help us help you!
Edited by Bruce Dorsi, February 10, 2016 - 04:09 PM.
  • Bolens 1000 and propane1 have said thanks
#14 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted February 10, 2016 - 04:58 PM
I think I might need to adjust my skids.I pulled it in to melt off and this pile was left after the snow melted.
  • KennyP and propane1 have said thanks
