Homemade Suitcase Weights
58 replies to this topic
#16 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted February 10, 2016 - 05:27 PM
Spent the day making the inserts. First off was making the jig to bend them on. I figured out what I needed from my drawing. Went to Ace Hardware for the supplies.
I fired up the woodburner to help heat the metal to bend.
Started bending things. Had to use the Mapp gas torch to supplement the heat.
Here's the hand hold pieces.
Here's one of the other parts.
I'll trim the second parts to fit the pan then weld in heavy wire from a cattle panel to keep things in place while pouring.
More to come!
  • olcowhand, DH1, limebuzz and 6 others have said thanks
#17 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted February 21, 2016 - 10:25 PM
Cool idea! Any more progress
#18 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted February 22, 2016 - 06:23 AM
Been working! Not much play time! Had to help daughter move this weekend.
#19 1967bolens collector OFFLINE
    Deceased
  • 655 Thanks
  • 1,441 posts
Posted February 28, 2016 - 05:43 PM
John Deere makes small suitcase weights but they have John Deere on them with the Deere I would like to make some with Bolens on them an the husky man lol
#20 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted February 28, 2016 - 06:00 PM
I hope to get back to this soon! I want KTP on mine!
  • limebuzz said thank you
#21 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 07, 2016 - 04:00 PM
I haven't forgotten this thread! Just no time to spend on it! Getting a little closer, though! Had a few minutes to make the pieces fit the mold pan. Just need a good day to spend getting the reinforcing wire welded onto things!
I need to trim these parts down about 3/32" in width as they are proud of the mold and I know the lead will shrink as it cools! Once I get that and the reinforcement done, then it's pour time!
WORK just keeps getting in the way! But, I want to go to Kentucky so I gotta put up with that! Maybe some extra GT $ too!
  • limebuzz, wvbuzzmaster, CRFarnsworth and 1 other said thanks
#22 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted March 08, 2016 - 03:20 PM
Kenny, they aren't going anywhere. Plow day is more important !
#23 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 08, 2016 - 03:21 PM
Like to have them done by then!
  • TomLGT195 said thank you
#24 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 10, 2016 - 07:03 PM
Got the reinforcing metal welded on. Setting up the pan to melt and pour from now!
  • limebuzz and TomLGT195 have said thanks
#25 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted March 10, 2016 - 07:24 PM
Don't forget to take the square out before you pour.   :smilewink:  :smilewink:
#26 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 10, 2016 - 07:26 PM
That's a temporary support! I'll have a bar across and clamped before I pour!
  • wvbuzzmaster and TomLGT195 have said thanks
#27 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 11, 2016 - 10:24 AM
I am not liking the pan for the mold. I set it on top of the wood burner to see how it would heat up and it is warping. I think I'll just make a mold for these using 1/8" material.
#28 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 12, 2016 - 09:24 AM
Since I am making a mold to replace the pan, I have revised the drawing accordingly. Made them a bit larger which should give me +/- 45 lbs. each.
I need to go get a 4' stick of 1/8" X 1-1/2" strap for this. I have the bottom plate for the mold. Need to mount my new HF Compact Bender so I can use it to bend the strap.
  • gopher, TomLGT195 and Mark 149 J. have said thanks
#29 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 12, 2016 - 06:38 PM
I got the bender mounted and a stick of metal. Proceeded to make the new mold. Found out I didn't need to add extra for the bends. It came out at 7.25 X 11.25. Oh well, just learning!
Cut the plate to size and cleaned it up. Clamped the new mold to that for welding.
I put some of this on the innards to hopefully keep things stuck together.
Got the innards fitted! I added some small angle across the bottom to keep that flat.
Hooked up the burner and added flame!
Success! Meltage is accuring!
Yep. it's melting!
Got it full! Time to chill out!
Now to get it out of the mold! Seems to have an attitude, you melted me in here, I'm not leaving! HMMMMMMMMMMMMMMMMMMMMMMM!
  • limebuzz, 1964Deere, wvbuzzmaster and 6 others have said thanks
#30 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 13, 2016 - 08:02 AM
I'm going out in a bit to see if it let go over night. If not, got some ideas. May have to cut some welds to get it to release!
  • limebuzz, MH81 and Mark 149 J. have said thanks
