Tire time
8 replies to this topic
#1 4tom OFFLINE
4tom
  • 162 Thanks
  • 175 posts
Posted February 08, 2016 - 04:33 AM
I now have a plow blade on my little sears lawn tractor. It works, but traction is not great. Current tires are worn low impact 15 x 6.00 6. Is there a good tire for winter traction? I would expect to use them year round.
Thanks,
Tom
  • GregoryOt said thank you
#2 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted February 08, 2016 - 05:03 AM
   get tire chains, use them int he winter then use your tires in the summer, I have Carlisle turf tires on my tractors with chains in the winter and never had any trouble.
                 Pete
  • MH81 and jd.rasentrac have said thanks
#3 MH81 OFFLINE
Posted February 08, 2016 - 07:27 AM
                 Pete
:ditto:
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted February 08, 2016 - 08:43 AM
CHAINS!!!
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,293 posts
Posted February 08, 2016 - 09:55 AM
yeah, be a member of the chain gang!
Edited by jd.rasentrac, February 08, 2016 - 09:57 AM.
  • cootertom said thank you
#6 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted February 08, 2016 - 04:55 PM
Turf tires with fluid and chains for me!
#7 4tom OFFLINE
4tom
  • 162 Thanks
  • 175 posts
Posted February 08, 2016 - 11:13 PM
Don't the chains dig up the blacktop?
#8 alleyyooper OFFLINE
alleyyooper
  • 945 Thanks
  • 420 posts
Posted February 11, 2016 - 08:36 AM
Chains only dig up the black top if you spin them and then if you don't set and spin in one spot for a long time sealer will coat the spot and you will never know.
I prefer woody carbide tipped ice studs my self, easy to install and easy to remove. You can put as many in as you have raised spots on the tires.
Also don't for get to fill the tires with Windshield fluid made for cold weather like 20 below. Or if you are wealthy add rim guard.
:D   Al
Edited by alleyyooper, February 11, 2016 - 08:38 AM.
  • limebuzz said thank you
#9 John Arsenault OFFLINE
John Arsenault
  • 2,858 Thanks
  • 1,298 posts
Posted March 08, 2016 - 08:46 AM
Did a test this winter ...Chains vs AG tires.....Chains win!
