Call this a Charger?
21 replies to this topic
#16 KC9KAS ONLINE
KC9KAS
  • 5,388 Thanks
  • 4,692 posts
Posted February 07, 2016 - 08:30 PM
These units won't charge a dead battery, but WILL maintain one.
I have 2 motorcycles with them for the past 3 winters and they work great!
Best $5 (each) spent!
Edited by KC9KAS, February 07, 2016 - 08:30 PM.
#17 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 07, 2016 - 09:35 PM
I have had get luck with this one.
noco-genius-smart-battery-chargers-auto-
  • Alc, KennyP and holdenboy1960 have said thanks
#18 Cvans ONLINE
  • 6,667 Thanks
  • 6,134 posts
Posted February 07, 2016 - 09:57 PM
  The last time I read the directions included with those HF maintainers it says that if your battery is below 12 volts they will NOT bring the battery back to a full charge, The ones I have work well but I check the voltage in the battery before hooking it up and charge them first if they are low,
  I like them but when the weather is cold the cords get very stiff and will crack were they exit the transformer.
#19 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted February 08, 2016 - 10:08 AM
I think, for 5 bucks you get brand-new scrap of no sale value. Why do other persons buy expensive stuff if brummagem products (worthless scrap) are so much better?
Edited by jd.rasentrac, February 08, 2016 - 10:08 AM.
  • oldedeeres and holdenboy1960 have said thanks
#20 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted February 08, 2016 - 11:25 AM
I have one of the Optima smart chargers and it wiil not pick up a dead battery
  • Cvans said thank you
#21 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 08, 2016 - 11:44 AM
I have been using the Battery maintainers at Wally world ($20) for years to keep my Motorcycle and ATV batteries charged.  I also keep one available for equipment that comes in with a low battery.  They have worked quite well and I have even brought back batteries that were pretty low, not dead but would not turn the engine over.  You do have to wait a while, I usually let them sit over night and the next morning I have a green light.  I've always heard that the slower you charge a battery the better.
  • wvbuzzmaster and BNK have said thanks
#22 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted February 13, 2016 - 08:47 PM
Well, went back to tool store and bought Two more BETTER (I hope) battery tender kits. These DO say need a full charged battery, won't charge, but will keep it up to charge and will shut-off when done and show diff color light for changes. These also have the bolt on wires and can leave plug on the tractor then, easy hook-up. SO, will go out tommorrow and check on those again and maybe get started and charging this time, will then install the keepers.
Edited by glgrumpy, February 13, 2016 - 08:49 PM.
