Started in on the 110 JD today( a long read with pics)
80 replies to this topic
#46 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted April 30, 2016 - 08:16 PM
It is coming along nicely.
Thanks it's been a struggle for me to actually finish a project from start to finish. I'm aiming to paint the rims an the couple other pieces next week an then all the white will be done. An on to fiberglass repair an purple for the hood.
Sent from my SM-S820L using Tapatalk
  • shorty said thank you
#47 shorty ONLINE
shorty
  • 4,348 Thanks
  • 4,514 posts
Posted April 30, 2016 - 08:44 PM
That sounds like me. Half way through a project I start losing interest. Then I barely get it finished and rush through the last and it never looks as good as I think it should.
  • backwoods and Oldford have said thanks
#48 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted April 30, 2016 - 08:48 PM
The hood on this will be base/clear so I'll spray it at a friends house I want the clear to turn out right on this. The white is enamel so I can't sand an buff it once it sets up good.
  • limebuzz and shorty have said thanks
#49 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 07, 2016 - 06:33 AM
As of yesterday afternoon everything is white
3683c6594dab5bd470e78a83587dc68e.jpgb11e0180e1656f4429756c26ca398382.jpgbd1ac1c9096092398351d158342b96d6.jpg99b7012d5f8bcaa6d0be33e66ffcbe1b.jpg67b6f14e15be181d0885a17f5189e69d.jpg
#50 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 08, 2016 - 01:58 PM
Last night I started assembly even though I still have to sand an buff part of the rear pan.1221c97f7a1d973264eac9c78fdb7813.jpg233734281db37864394a7bdaf09e3dc0.jpg
#51 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 09, 2016 - 08:49 PM
Well after tonight it's ready to buff tomorrow the wiring is ran an the pan is bolted down to new rubber mounts.
002c4e5004822e28d19424e8cfb1f99c.jpgb2bc10a8c349cca74e17ae7f37e61cd0.jpg839666f51bdd5bc98298395e41e1ffb2.jpg
#52 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 10, 2016 - 09:18 PM
Pics from tonight an i finally started working on fixing the hood since i hate fiberglass work I held off on it.
ba466c6a9906e279fda0056e1b9dc809.jpg800efbaaebaf43df7dbb6122d632dcf7.jpg2820f91671847287dae71e844d11849b.jpgc1c871686735843e0b6a381fe4410060.jpg38c82c8ad00becf26e5ff5bdf8e9dcc9.jpgdb0aa7944fe1ae10b435730484b61762.jpg152db139ccce08a7d2b042633a0ecd9a.jpg5f7295a8804da5a19d7419db38f656fe.jpg
  • KennyP and Oldford have said thanks
#53 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 13, 2016 - 09:56 PM
Well the.pictures in the above post failed its been way to long since i have done glass work an i didn't add enough hardener. So 2 days ago I took a spreader an scraped to resin an mat off the hood scrubbed it with lacquer thinner let it dry an started over with more hardener. It worked this time an yesterday I flipped the hood an did the outside of it since the inside was done the previous night. Tonight I put on the first coat of a light weight polyester body filler I sanded most of it down smooth before I came in for the night hopefully by the time I come in tomorrow for the night it'll be in primer.
  • KennyP and Cat385B have said thanks
#54 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 15, 2016 - 07:58 PM
Ok.here's an update as of yesterday I have to hood fixed finished the filler work an sanded then covered it all in a few coats of a primer/sealer.6bfb4368fb0ac501b065de7da5c53d13.jpg0778df72214b5883b681cbbaa2d4c892.jpg0015f83010821089b66442e9e3d5d64c.jpg
  • limebuzz and KennyP have said thanks
#55 Cat385B ONLINE
    Therapy CAT
  • 12,650 Thanks
  • 9,352 posts
Posted May 15, 2016 - 08:21 PM
Is the learning curve on fiberglass work long? I've never done it.
  • backwoods said thank you
#56 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 18, 2016 - 09:01 PM
It's very hands on, in all the 6 years of auto body schooling I have none of the instructors really got into how to repair it for students to get hands on experience so I asked a few people I know that have done it for advice an a little engeunity an it worked. As far as a learning curve I would say to you have your patch pieces cut an ready before you mix the resin an hardener, apply some resin to the repair area first then set the patch in place an work the patch into the resin, apply more resin to the patch an work that in try to spread the resin evenly like you would a regular filler to save work after it sets up.
#57 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 18, 2016 - 09:04 PM
I forgot I had pics of the hood sitting on the tractor so here they are an.a pic of the rims that are half painted. As for the hood well I have two flow meters ( runs ) that need to be sanded out so tomorrow I'll sand them out an spray it again after Avery goes to.bed I'm happy with the purple that i picked out an i can't wait to.pick the seat up since i know that is done too.
e81089c3686061836c87c90499f849f0.jpg655ae32f6c88c7ac2d5db7d7bcf6d83b.jpgabf6929dbaf5fe0d989f9a43ca9a11c1.jpgffdf5fbafd0f499c1e41e9d122e5d3e1.jpg
#58 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 19, 2016 - 08:28 PM
Hopefully by this time tomorrow I'll have pics of it all together but the seat which I'll be picking up next week
  • KennyP and Greasy6020 have said thanks
#59 backwoods ONLINE
backwoods
  • 2,547 Thanks
  • 2,780 posts
Posted May 20, 2016 - 09:11 PM
Well here it is guys the pictures everyone has been wanting to see the color of the hood.
#60 KennyP ONLINE
  • 32,234 Thanks
  • 42,033 posts
Posted May 21, 2016 - 05:50 AM
Plum Crazy Purple! Cool!
