Started in on the 110 JD today( a long read with pics)
80 replies to this topic
#31 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted March 13, 2016 - 12:34 AM
Re the seat, its hard to do those molded seats without having seams in it. The fabric/vinyl will bunch up in the bend areas.
What I do doesn't look factory, but does look ok and works pretty well for me.
I peel the old vinyl off the foam - use a sharp putty knife to "skin" the old vinyl off. Then I cut the upright (back) section of the foam off the bottom section and upholster it as 2 pieces.
Permatex makes a spray headliner/upholstery glue - comes in an orange spray can - I use that to glue the new vinyl onto the foam base, putting a long tail over the back of the seat base and onto the bottom of the pad. This helps keep the foam from getting wet if it rains on the seat. I build the base (bottom) cushion first, then glue the finished assembly onto the metal seat pan. I put some weights on the seat to hold it onto the pan overnight so the glue sets up good.
Then do the same thing with the seat back, again putting a tail on the bottom edge that goes around to the back. If you scrunch the upright down when you glue it to the base, you only get a small line where the 2 edges meet that is not noticeable.
Then I glue the apron onto the side edge of the foam and to the seat base and put the striping on to hold the fabric onto the frame edge.
Takes longer to explain than to do - about 30 minutes work and a couple days for the glue sections to dry.
I buy my vinyl and supplies online from a fabric supply place - is cheaper that way. And definitely go with marine grade vinyl.....
If your pad foam is torn or ripped, you can use the same glue to glue the tears back together or add some replacement foam if you need to. If you need replacement foam, keep your eyes open for a discarded sofa cushion or stuffed chair cushion - it will give you more than you need for free!
  • Alc, backwoods and tomgo1 have said thanks
#32 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 13, 2016 - 09:14 AM
Just a little update the motor is rebuilt with new bearings an gaskets the carb is rebuilt now all I have to do is paint the blower housing an the motor is done other then decals. I pull the rear section an rear axle out of the it should be easier to paint all the tight spots now an replace the broken parking brake spring an anything else I find. The seat pan is welded an painted I did get my quote to have the seat done an for $100 im not going to try an do it myself an that will include new foam.
  • Oldford said thank you
#33 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 13, 2016 - 09:36 AM
uploadfromtaptalk1457879736838.jpg uploadfromtaptalk1457879742315.jpg uploadfromtaptalk1457879748201.jpg uploadfromtaptalk1457879755088.jpg uploadfromtaptalk1457879760832.jpg uploadfromtaptalk1457879765159.jpg
#34 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 13, 2016 - 06:05 PM
An today's progress uploadfromtaptalk1457910274163.jpg uploadfromtaptalk1457910281676.jpg uploadfromtaptalk1457910289384.jpg uploadfromtaptalk1457910295604.jpg uploadfromtaptalk1457910302492.jpg uploadfromtaptalk1457910311313.jpg
  • limebuzz and KennyP have said thanks
#35 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 21, 2016 - 06:28 AM
Well looks like this week the progress will resume after the cold snap this past weekend im going to tape up the blower housing serial tags either tonight or tomorrow an get that painted. I did pick up my rear tin mounting bushings from the dealer on Saturday.
#36 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 01, 2016 - 08:30 PM
The seat is off to get new vinyl an foam I should have it back in a couple weeks
#37 jabelman OFFLINE
jabelman
  • 2,216 Thanks
  • 1,589 posts
Posted April 01, 2016 - 08:43 PM
looking great, keep the updates coming nice to see members restoring tractors
  • backwoods said thank you
#38 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 02, 2016 - 06:31 AM
Thanks I'm going to be working on it more today an after this one is done I have 2 cubs to rebuild
#39 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 02, 2016 - 04:27 PM
How do you guys remove old decals from fiberglass hoods? An here pics to where I stopped till after I warm up.3e3a4c669f7ef71aea22cdd80ebb9029.jpg606fe59fc1fc71f6b606102f5c2d8228.jpg24a1bf785a0c5881d8e3a7a2b9de7a5c.jpg462d6a373c0553c85636575314551ca6.jpgce3d6cde1f0914b243ec5620b8afb61c.jpg
#40 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 13, 2016 - 05:09 PM
Well the old decals are off the hood a fender pan an i got a surprise in the mail today from another member mine are in the center the new ins are on the out side.
Sent from my SM-S820L using Tapatalk
#41 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 19, 2016 - 06:03 PM
The motor is all together an the decals are finally on.
6f155a93ac0214ddc3e0f5ffcf629acc.jpgdacc0b97dd923a008bbd9ae0fbb0e5a0.jpg68cd3ae934bf32688479d9f1d5d46ddf.jpg
  • limebuzz and shorty have said thanks
#42 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 28, 2016 - 10:53 AM
Well the plan for Saturday is to paint the frame an rear end an tins then one day next week.bolt the motor in I would like to get all the white parts done this weekend. I guess time will tell how much I can get done
#43 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 28, 2016 - 10:55 AM
f2bc530ec00413abfa5f1a98667ab8ee.jpg07338b22b6731f56ad386e2a94addee0.jpg7bfc4b2138425a182e87894d2fab27f8.jpg7809aeee05883291c7441ef997d52d32.jpg
An of course Avery joined in on scraping grease an dirt off.
  • KennyP and shorty have said thanks
#44 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 30, 2016 - 08:07 PM
Today was paint day here is the updated pics
833e23bd5bccfc30bcb1136ede37d73d.jpgcf750f0e8ef22bd9b132dc0a8136678b.jpgc8623edcab92600f45e720f54c4f118a.jpg945a4d29b1e86515d7079c1d9a9c2935.jpg046533a1f5f849071b870e7b5373641b.jpg830e64f44540221193d67a2aca0d0904.jpg3ed99876de194f57dc28401c02c71678.jpgac74742f219a7f058376595379301a45.jpg197ae3db3b6a95ddf96aa9f910436bfd.jpg
  • shorty said thank you
#45 shorty ONLINE
shorty
  • 5,463 Thanks
  • 5,256 posts
Posted April 30, 2016 - 08:11 PM
It is coming along nicely.
