Started in on the 110 JD today( a long read with pics)
80 replies to this topic
#16 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted February 14, 2016 - 09:33 AM
Never thought of that I still need to redo the seat an foam
It's not as hard as you think. marine vinyl is cheap. I never done it before but I used the old seat as a pattern.
make sure you get heavy duty thread. I got it hobby lobby for 3 bucks. I did have my mom sew it all together I have no idea how to run a sewing machine and really didn't want sew my fingers together. all said and done I recovered it for about 30 bucks and have ton of material left over.
here's the link
http://gardentractor...m/?fromsearch=1
Edited by jabelman, February 14, 2016 - 09:35 AM.
#17 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 14, 2016 - 09:39 AM
here's the link
The seat on the 110 is a one piece so no sewing will need to be done im just not sure how to get the banding that holds the cover down to the seat pan
#18 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted February 14, 2016 - 09:42 AM
there's a dude on here Chevy 29 or 29 Chevy he did a really nice write up about seat recovering I picked up a few tips from that post.
  • backwoods said thank you
#19 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 14, 2016 - 09:47 AM
I was thinking having the cover embroidered though but depending on the quote for getting it done comes back
#20 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 19, 2016 - 10:39 AM
Here is the lovely seat that I'm waiting on a quote still
#21 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 19, 2016 - 05:27 PM
Well i had to change the window regulator in my Durango so I went in the garage an.pulled the rear tin a seat apartuploadfromtaptalk1455920798974.jpg uploadfromtaptalk1455920804734.jpg uploadfromtaptalk1455920808426.jpg
#22 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 20, 2016 - 06:13 PM
Ok how do I remove this from the pulleys??uploadfromtaptalk1456009920924.jpg
#23 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 20, 2016 - 07:09 PM
Never mind i.figured it out once I removed the motor. So.here is an.update as of a little bit ago.of how Averys 110 sits the oil is drained carb is full of gunk from gas in July that was treated.
uploadfromtaptalk1456013234716.jpg uploadfromtaptalk1456013246076.jpg uploadfromtaptalk1456013254530.jpg uploadfromtaptalk1456013261555.jpg uploadfromtaptalk1456013269270.jpg uploadfromtaptalk1456013272974.jpg uploadfromtaptalk1456013277126.jpg
#24 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 28, 2016 - 09:29 AM
No pictures yet but yesterday I removed the seat cushion from the seat pan an today after work im going to work on cleaning the pan an treating the rust then hopefully getting a coat of paint on the seat pan today I went with a gloss white tractor enamel.
#25 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 28, 2016 - 05:20 PM
uploadfromtaptalk1456697941231.jpg uploadfromtaptalk1456697955705.jpg uploadfromtaptalk1456697963735.jpg uploadfromtaptalk1456697977762.jpg uploadfromtaptalk1456697985917.jpg
#26 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 28, 2016 - 05:21 PM
uploadfromtaptalk1456698019613.jpg uploadfromtaptalk1456698025244.jpg uploadfromtaptalk1456698033003.jpg uploadfromtaptalk1456698039710.jpg uploadfromtaptalk1456698058452.jpg uploadfromtaptalk1456698063392.jpg uploadfromtaptalk1456698069482.jpg
#27 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 28, 2016 - 05:23 PM
So these are from this afternoon an of course I got Avery thought she should be part of the cleaning process. The seat pan has been treated with the ppg 2 step process as well as the frame where I wire brushed it.
#28 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 04, 2016 - 09:01 PM
With luck an help from a friend tomorrow the motor will be rebuilt an the seat pan welded up an ready for paint.
#29 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 05, 2016 - 09:04 PM
Well the motor is torn down an I'm waiting for a crank bearing to come that I had to order. So in the mean time I will get the block an oil pan painted.uploadfromtaptalk1457229809182.jpg uploadfromtaptalk1457229815918.jpg uploadfromtaptalk1457229828935.jpg
#30 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 09, 2016 - 08:21 PM
Well my bearing came in an the motor will go together this Saturday tonight I pressure washed the tractor to get the remaining grease off. Also the seat an block are painted an look.great.I'll try to get pics tomorrow of them.uploadfromtaptalk1457572876325.jpg uploadfromtaptalk1457572881492.jpg uploadfromtaptalk1457572888242.jpg uploadfromtaptalk1457572894459.jpg uploadfromtaptalk1457572897697.jpg
  • jimbobbillyray said thank you
