Simplicty "D
No replies to this topic
#1 chrispg OFFLINE
  • 129 Thanks
  • 78 posts
Posted February 05, 2016 - 09:44 PM
Have made some progress on my Simplicity tractors and implements. I've gone a bit fast but it has been a blast.
There some early pictures here and in progression.
Some detail work to get done. I have all the wheel weights and front weights for both tractors.
I found the coulter for the plow and need to sand blast it and get it together with the plow>
Waiting on Idler arm bracket and spring for the smaller "D" tractor. Then I will fabricate the idler arm. Then I can run the rell mower. I still need to make the hardwood rollers
Ran the sickle bar on the "V" and it works good. I need to grease everything up. Got the carb rebuilt kit coming and I hope it has the the needle valve seat that goes into the fuel bowl because it was cracked and leaking fuel.
Next project is a the Danville seeder which I all the parts either here or coming.
Then I have my eye on a "W" with a snow-blower and a 30" rototiller.
  • Rock farmer said thank you
