* - - - - 1 votes
CV Joint drive shaft
9 replies to this topic
#1 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 04, 2016 - 12:04 AM
Pondering a thought about this Cub Cadet drive shaft that was removed from a 1440 I parted...has anyone done a conversion like this for your hydro drive line? I have logged many hrs on the very same drive line with no issues...ever! Notice the zerk fittings at each end. I have seen the u joint conversions but never a CV Joint. I'm getting some vibration again on our 1250 and the culprit is the flange at the pump...again. Rag joint type joints from engine to pump OEM style.
  • holdenboy1960 and chieffan have said thanks
#2 EricFromPa OFFLINE
EricFromPa
  • 3,663 Thanks
  • 3,115 posts
Posted February 04, 2016 - 07:09 AM
I tried to put a 1440 shaft on my 129 and it's to short.You will need to make a new thicker hub to bolt onto your engine.I can't remember if the splines are the same on the pump end.It's been a couple of years since I had it apart.
I still have the 1440 shaft in the shed for some reason or another.
Edited by EricFromPa, February 04, 2016 - 07:10 AM.
  • BNK and chieffan have said thanks
#3 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted February 04, 2016 - 07:34 AM
The cv is a lot nicer, my brother did it on his 1772 and it runs really nice now. I don't see why with some work  you cant make it work, you may have to get some adapters made though. Here's his build thread http://gardentractor...772#entry571568
  • Alc, BNK, holdenboy1960 and 1 other said thanks
#4 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 04, 2016 - 07:58 AM
1440,1641,1860's & up yes they are splined at the pump, but the early pumps are not. At least mine aren't at the pump. Fabricating a thicker hub at the engine, my thoughts exactly. The fan is bigger also, thinking it might be too close to the charge pump especially if you have the fittings and hard lines for a lift. Currently there is no hyd lift on the 1250 at this time but I have been saving and hunting parts to do a conversion some day.
  • chieffan said thank you
#5 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 04, 2016 - 08:02 AM
That's it!!!!! Thank you!!!! I even made a comment on his thread and forgot I did....
#6 chieffan ONLINE
  • 10,165 Thanks
  • 6,647 posts
Posted February 04, 2016 - 08:15 AM
I have replaced the rag joints with 4" hay baler belting, they kind used for the large round bales.  Have one running for close to 2 years now and no issues.
  • Alc and BNK have said thanks
#7 Cub123 OFFLINE
Cub123
  • 97 Thanks
  • 50 posts
Posted February 09, 2016 - 03:23 PM
I just noticed this thread, a guy on another forum makes the adapter for older pumps to the CV shaft, and he could probably make a adapter for the engine if you know how long it needs to be. I should think the fan would work, but you may need to trim blades, which I've done before with success.
http://img.photobuck...91.jpg~original
  • BNK said thank you
#8 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted February 09, 2016 - 07:50 PM
Very good pic of the pump adapter! Thanks for posting!!!
  • Cub123 said thank you
#9 Cub123 OFFLINE
Cub123
  • 97 Thanks
  • 50 posts
Posted February 09, 2016 - 08:11 PM
Your welcome, should you want the guys contact info to talk to him about the possibility of an engine adapter just send me a PM.
#10 olcowhand ONLINE
  • 41,198 Thanks
  • 31,429 posts
Posted February 09, 2016 - 08:15 PM
adapter.jpg Here's the pic for easier viewing:
  • Cub123 and BNK have said thanks
