1973 140 H3 Green Machine
65 replies to this topic
#46 propane1 ONLINE
propane1
  • 9,121 Thanks
  • 4,275 posts
Posted April 06, 2016 - 05:20 PM
Was doing some other repair in that area and if you remove that set screw, that first arm should slide off, in it or the next arm there is a small woodruff key, don't loose that. Then the last arm comes off, can't remember what holds that on, if any thing.
Then all the levers should come out.
Noel
  • VintageIronCollector, 637Yeoman and leolaeb69 have said thanks
#47 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted April 06, 2016 - 06:14 PM
Noel
thanks. seems like mine just needs to soak with some penetrating fluid.
  • 637Yeoman said thank you
#48 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted April 13, 2016 - 07:09 PM
Got a grill for it today and couldn't wait so I painted it. Think it looks better now
  • KennyP, hdg4400, Leonard VanCamp and 1 other said thanks
#49 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted April 17, 2016 - 07:53 PM
Got a tiller for my 140 yesterday
  • KennyP, Leonard VanCamp and 637Yeoman have said thanks
#50 KennyP ONLINE
  • 40,102 Thanks
  • 46,756 posts
Posted April 17, 2016 - 08:15 PM
Nice score there!
#51 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Do you have the PTO that goes on the back of the pump?
#52 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted April 17, 2016 - 08:49 PM
nope.
#53 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted April 17, 2016 - 08:50 PM
Here's someone's homemade lift bar that came with it. hopefully it'll still work
#54 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted May 05, 2016 - 09:49 PM
Well after realizing the tiller was only 26" wide it was too narrow for my 140 and I didn't want to invest in an extension so a buddy came this evening and bought it.
#55 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted May 23, 2017 - 07:52 AM
Wow it's been a long time since I've updated this thread but within the next few weeks I am planning on finally getting in the extra k321 i had bought and got rebuilt with all new parts so hoping to get another 50 years out of that engine. Also going to add a hour meter for maintenance reminders and change a few leaking hydraulic couplers and change fluid and filter in trans. just need to find the drain on the trans cause I assume I fill it through the dipstick tube. If all goes well I will have a nice show tractor during the year and a plow beast in the winter time. Thanks
  • SupplySergeant and 637Yeoman have said thanks
#56 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted May 27, 2017 - 10:47 AM
Well she don't look like much but here is the rebuilt engine. I chose not to paint it so it would match the original condition of the tractor and not stick out like a sore thumb.
I heaved the old engine out and got the new one in and all hooked up yesterday and started the break in process on the engine by running it at about mid throttle for 15 minutes while changing up the rpm every now and then. Drained the oil to make sure no metal shavings and not a trace and I was super happy. Now i gotta go get some more oil for it then I can run it for the next three hours just casually driving it around then I can change the oil again. I'm probably changing the oil more than I have to for break in but as cheap as oil is I'd rather be safe than sorry.
  • KennyP and 637Yeoman have said thanks
#57 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted May 27, 2017 - 10:48 AM
Just throwing this pic in to show how pretty she was lol. Never be that clean again!
  • KennyP, Trav1s and 637Yeoman have said thanks
#58 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted May 27, 2017 - 08:06 PM
Finished breaking engine in and got it all back together! Ignore the messy shed lol
  • Alc, KennyP and 637Yeoman have said thanks
#59 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 28, 2017 - 04:55 AM
Looks good, hows she working? Those 140's are tanks!
#60 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted May 28, 2017 - 06:56 AM
Radio got pulled apart more today
And also polished hood. Will make for a decent spare hood even though there's a hole, and latch rivets are ripped out and crack in the front. I laid it next to my other hood for comparison.
What'd you do with the radio. I hope you saved the shell. If so, you could re-radio it with an updated system. I would if I had that shell. At least the shell looks to be in good condition. I do hope you still have it for a rainy day.
Sent from my S60 using Tapatalk
