482S Exhaust Manifold
48 replies to this topic
#31 oddfirecj5 OFFLINE
oddfirecj5
  • 73 Thanks
  • 262 posts
Posted February 03, 2016 - 06:10 PM
aren't the manifolds the same with the 20, 23 horse engines?
  • SC Farmer said thank you
#32 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted February 03, 2016 - 06:43 PM
On the Bolens , yes
#33 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 03, 2016 - 06:47 PM
John Deere?
At first I thought it might be for a JD 400, which also used a K-series twin, but those tractors had two exhaust manifolds.
#34 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 03, 2016 - 09:40 PM
Yes your right I looked at the two parts engines that I have that came out of John deeres and they have two.
#35 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 04, 2016 - 12:33 AM
It occurred to me that maybe the oddball exhaust manifold I have is for one of the zero-turns that used the Kohler K-series twins.
#36 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 04, 2016 - 05:54 AM
Doug, check out this listing on eBay - looks kind of like the part you showed in this post, although a much rustier one...
http://www.ebay.com/...SkAAOSwGotWnpJH
According to the ad, it goes to a K582...
#37 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 04, 2016 - 09:46 AM
Thanks for the link. Too bad that the seller did not say what the manifold came from. Maybe he doesn't know, and is just parting out the engine.
#38 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted February 04, 2016 - 03:19 PM
Hi Jim,
The manifold i have is not from a bolens. It is only threaded no flange for bolting the muffler to. It came off an kohler generator.
Sorry,
Mike
#39 BolensChrisUK OFFLINE
BolensChrisUK
  • 603 Thanks
  • 263 posts
Posted February 04, 2016 - 03:41 PM
I got some off K532 but bit far away from you
#40 oddfirecj5 OFFLINE
oddfirecj5
  • 73 Thanks
  • 262 posts
Posted February 04, 2016 - 08:43 PM
On the Bolens , yes
so the 20, 23 and the 18 are the same manifold then?
#41 oddfirecj5 OFFLINE
oddfirecj5
  • 73 Thanks
  • 262 posts
Posted February 04, 2016 - 08:44 PM
i might have one...i'll look in the pile of parts i have. that's if they are all the same
#42 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 04, 2016 - 11:27 PM
Yes
#43 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 05, 2016 - 04:57 PM
Thanks to all who looked in their pile of parts for the manifold I needed!  Even all the way across the pond!  I've located one here and it will arrive next week (thanks Bob!) and then the fun begins getting the old one off! :wave:
  • olcowhand said thank you
#44 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 08, 2016 - 04:20 PM
A follow-up on the exhaust manifold - it should be here by the weekend and hopefully I'll have the old one off by then - broke one bolt off, but it broke up high and I should be able to get hold of the stub pretty easy once I "gently" remove the other three.  Dang rusted bolts! While making room in the engine compartment to work, I removed the back section of the shroud, which also acts as a firewall of sorts.  Discovered that the rectifier/regulator is fried - one lead was burned completely off, obviously the one that allows the battery to charge, as the tractor did run with it missing.  So, I'll be replacing that and I'll be moving it's attachment location away from the hot firewall as well.  Pretty poor selection of an attachment area by the Bolens folks way back when...
Also of interest:  while trying to identify if the rectifier was a 15 or 30 amp model (it's a 15 amp), I discovered that the flywheel (and some other items as well - the intake manifold for example) is red!  Obviously, the motor came from a Wheelhorse at some time in the tractor's life!  Ya never know what you'll find in one of these restore jobs, do ya?   :wallbanging:   I love it though, except for the $$$ part!
Jim
Edited by Lorisfarmer, February 08, 2016 - 05:25 PM.
  • LPBolens said thank you
#45 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 09, 2016 - 06:15 AM
I thought I'd share a couple of pictures:  Check out the rectifier and notice that one of the AC leads is basically not even there.  Also here's a picture of the Wheelhorse red flywheel...
