482S Exhaust Manifold
48 replies to this topic
#16 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 03, 2016 - 10:00 AM
Thanks, I thought that was the number but it looks different in the diagram compared to the actual part in the manual I have
Even If I heavily discounted it , best I could do is about $480
  • SC Farmer said thank you
#17 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted February 03, 2016 - 11:15 AM
That price is absurd!   I know it's not your fault Brian, as some want near $550.
#18 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 03, 2016 - 12:30 PM
This goes back to what I said a few months ago,us guys as suppliers get a bad rap for some of the pricing we have,we can't control what the manufactor charges for the new parts,exactly why more and more of these old tractors are getting scrapped,that's why I grab up what ever parts tractors I can get before they wind up being crushed,at least having and selling used parts also helps keep these tractors running and around
Edited by blackjackjakexxix, February 03, 2016 - 12:31 PM.
  • olcowhand, WrenchinOnIt, ClassicBolens and 2 others have said thanks
#19 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 03, 2016 - 12:51 PM
The bolt is just not there.  The threads are pretty rough though.  Oh, the muffler is NOT very good.  Works okay, but the screen is rusted out and mostly missing.
Rick, I appreciate you checking for a good used manifold.  And I have been soaking the existing bolts with PB.  Tractor is up on blocks right now (for a bit) while I do some other need maintenance, so it can soak in real good.
#20 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 03, 2016 - 12:52 PM
Yikes!  $480!  I'll need to do something else there for sure!
#21 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted February 03, 2016 - 01:25 PM
The part number for the Bolens exhaust manifold is 277482 and is NLA with a list price of $511.89. Now if you need one I may have a used one here and will check. Just send a PM
  • blackjackjakexxix and SC Farmer have said thanks
#22 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted February 03, 2016 - 01:57 PM
The part number you reference is for the Bolens listing under Kohler( why I first posted NLA), upon further research the number I listed and Brian looked up is for the basic manifold still available and was told by the only difference is no threaded hub out the top, but has the same side exit as the Bolens listed one, and will work ,you know this to be different? Bad info?
Edited by WrenchinOnIt, February 03, 2016 - 01:58 PM.
  • Bolens 1000, LPBolens and blackjackjakexxix have said thanks
#23 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted February 03, 2016 - 02:38 PM
 With talking to my Kohler rep the side was closed and the pipe plug was were the muffler would go on most setups or unless it was a special setup. from what I do see there was at least 4 different ones and from my kohler dis they are all NLA. The only ones I have ever seen open on the side was for the Bolens. All the other ones I have seen they exhaust out the top and closed on the side. Now this is just the info I am aware of.
  • blackjackjakexxix and WrenchinOnIt have said thanks
#24 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 03, 2016 - 03:27 PM
I have an odd NOS Kohler exhaust manifold for the K-series twins. As you can see from the pic, if it was installed on a Bolens LF, it would exhaust to the rear towards the dash tower, or right through the hood if you tried to use the threaded outlet. I have no idea what it was originally intended for.
  • Bolens 1000, blackjackjakexxix, WrenchinOnIt and 1 other said thanks
#25 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 03, 2016 - 05:00 PM
John Deere?
#26 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 03, 2016 - 05:01 PM
Alright who would like me to start sand casting these because I bet I could get them made for way less then $400+.
  • Bolens 1000, LPBolens, WrenchinOnIt and 1 other said thanks
#27 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 03, 2016 - 05:06 PM
I'm sure some guys would want them!
Generally when a part is ready to become obsolete Kohler likes to add $75-$200 to the list price and I guess they figure they mine as well try and strike it rich with the handful they have in the warehouse at the time.
  • wilberj, LPBolens, blackjackjakexxix and 2 others have said thanks
#28 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 03, 2016 - 05:09 PM
If I had a NOS one in my hands I could take it to a caster and get them made. I would then take them back to were I work and have the machining done.
  • Bolens 1000, WrenchinOnIt and SC Farmer have said thanks
#29 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted February 03, 2016 - 05:18 PM
If it becomes a serious endeavor I will get a NOS one into your hands!
Edited by WrenchinOnIt, February 03, 2016 - 05:18 PM.
  • wilberj, LPBolens, blackjackjakexxix and 1 other said thanks
#30 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 03, 2016 - 05:21 PM
I'll take a used one into the boss and see what he thinks if it worth it I'll get back to you.
  • WrenchinOnIt and SC Farmer have said thanks
