482S Exhaust Manifold
48 replies to this topic
#1 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 02, 2016 - 09:30 AM
Anyone by chance have an exhaust manifold for an 1886-02 laying around? The one I have has a break at the muffler connect that I would like to replace. PM me if you have one you want to sell. Thanks!
#2 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 02, 2016 - 10:10 AM
Let me take a look
  • SC Farmer said thank you
#3 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 02, 2016 - 11:34 AM
Ok,the only one I have is broke where it bolts to the engine,sorry
#4 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted February 02, 2016 - 12:36 PM
I may have one I'll check after work
Mike
#5 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 02, 2016 - 05:33 PM
What do you mean by it has a break?
Edited by wilberj, February 02, 2016 - 05:33 PM.
#6 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 02, 2016 - 07:06 PM
Rick, mine is "cracked - chipped" at one of the bolt holes for the muffler. I'll post a picture of it tomorrow.  Jerome, my picture should answer your question.  Once the picture is uploaded, I'd like opinions on if it could be welded.  I know nothing about welding - not even sure if cast iron CAN be welded!
Edited by Lorisfarmer, February 02, 2016 - 07:12 PM.
#7 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 02, 2016 - 07:07 PM
Mike - that would be great - let me know if you have one!
#8 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted February 02, 2016 - 07:25 PM
Yes, it can be welded, but it's more involved.  First it has to be very clean.  Then the whole piece needs to be heated really hot, welded, then put right back into the high heat, then brought down to room temps over hours.  If not done right, it'll just crack next to the weld.  I use nickel or stainless rod.  Nickel works best.
  • blackjackjakexxix and SC Farmer have said thanks
#9 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted February 02, 2016 - 07:28 PM
Daniel is right, it can be welded as he stated. It can also be brazed or flame welded with a good bronze rod.
#10 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 03, 2016 - 05:48 AM
Olcowhand and Texas - Thanks for the info!
I think I'll be taking it to a good muffler or machine shop for sure. That work is way beyond my pay grade.  Of course I first have to get the [email protected]##@% muffler and manifold off the tractor!
My preference is to just replace it with a good used one, if I can find one.
Edited by Lorisfarmer, February 03, 2016 - 05:49 AM.
#11 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted February 03, 2016 - 06:04 AM
Here's a picture of the damaged exhaust manifold and exhaust pipe.
  • Rock farmer said thank you
#12 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted February 03, 2016 - 06:53 AM
Looks rough, I vote for replacement with a good used one, memory serves your 86 stock muffler is in good shape ? Get it off by snapping or twisting off what's left of other two and set it aside , I wouldn't take it to the muffler shop. Those manifold bolts into the jugs can SUCK to remove, snapped many off and have had many come right out unencumbered ,some pre-soaking with Kroil or PB can't hurt. I've repaired these manifolds by welding and am confident I could repair yours, however I will offer this; yours can be fixed, last resort IMO, look for a good used one, I may have some used ones if Mike doesn't, I will try to look tonight, I do have NOS ones but they are pricey (NLA from mfg) go slow on those manifold into engine bolts, several days of pre-soaking and no impact wrench (IMO) good luck.
Edited by WrenchinOnIt, February 03, 2016 - 06:54 AM.
  • Bolens 1000, Alc, Paulgo and 1 other said thanks
#13 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 03, 2016 - 09:21 AM
What was the part number for these?
#14 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted February 03, 2016 - 09:26 AM
277013-S superseded to 277219-S and I stand corrected STILL available but OUCH!
  • Bolens 1000 and SC Farmer have said thanks
#15 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 03, 2016 - 09:58 AM
Where that bolt is missing,is it broke off or just not there
