Need a D.B. Guru
4 replies to this topic
#1 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted February 01, 2016 - 07:40 PM
I got a David Bradley in a package deal.  Didn't really want or need it, but it came home anyway.
I'm not real famliar with D.B.'s.   I'm going to put an engine on it and see if it works.
On the inside of the hubs is what looks like a pulley for a flat belt.  What is it for?
Just behind the pulleys is a rod sticking out, what is it for?
Is it normal to have two pulleys on the trans/axle input shaft?
Model number is 917.57560    series211   Is it required to keep some baling wire on the handle bars?  :D ​        Rick
  • Traill95 and chieffan have said thanks
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 01, 2016 - 07:48 PM
the tractor has part of the reverser system on it, those are the hubs you would need, and the rod thingy held one of the four reverse blocks that's missing from each side.
And yes baling wire is a require item to all walk-behinds.
  • Gtractor, Alc, CRFarnsworth and 2 others have said thanks
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted February 01, 2016 - 09:51 PM
Thanks for the info.
   So I have part of a reverser system.  I guess that means I'll still have to pull it backwards!!    Rick
Anyone interested in this  machine?
Edited by CRFarnsworth, February 01, 2016 - 09:52 PM.
  • Lauber1 and chieffan have said thanks
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 01, 2016 - 09:54 PM
well yes until you spend a couple hundred buying the missing stuff. There are folks around that have them to sell, so just put out some feelers and see who has what you need.
#5 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted February 01, 2016 - 09:59 PM
I'm figuring that I'll let this one go.  I've only got about 17 other projects to work on.  Rick
  • Lauber1 said thank you
